Front Brake Hose Replacement.
Old Jan 25, 2012 | 01:55 PM
Scaper's Avatar
Scaper
Hello all, I recently found out that I need to replace my ds front brake hose. I have never done this before so I was wondering if there are any tips or advice you guys can give me on how to do this properly. I also was wondering if I need to bleed all four brakes when I am done or if I can get away with just bleeding the one.
Thanks
Old Jan 25, 2012 | 03:27 PM
tjc transport's Avatar
tjc transport
i ain't rite
i replace them in a set and the front steel lines also, because the steel line usually breaks when trying to remove the rubber line.
so i save myself the headaches and just order everything before starting the job.
Old Jan 25, 2012 | 03:28 PM
Aune163rd's Avatar
Aune163rd
If you unseal any part of the brake system...you never know where air can get into....i would say its safe to just bleed the one, but brakes and me hardly ever get along. The hose itself should be fairly easy.
Old Jan 25, 2012 | 03:59 PM
Scaper's Avatar
Scaper
Good point about the steel line...I think I will replace the steel line as well.
Old Jan 25, 2012 | 07:36 PM
tecgod13's Avatar
tecgod13
Spray the connections with your favorite penetrating lube a few times in the days before you go to switch it out. Also spray the brake bleeder and pray that will loosen as well. Actually it might be wise to try and crack open the bleeder before you do anything else, just in case its frozen up.
I've also had terrible luck with steel lines when replacing hoses, or rear wheel cylinders. They almost always have been rusted together. Usually I can get the line nut to turn without too much trouble, but 95% of the time the line is rusted to the nut and twists/breaks the line
To prevent future issues, I liberally coat the new connections (including the section of line that rotates inside the nut) with anti-seize.
Old Jan 25, 2012 | 07:42 PM
Scaper's Avatar
Scaper
Great advice...thanks alot!!
2000Ford2000
19
Feb 10, 2021 09:51 AM
MBBFord
Jul 1, 2007 07:43 AM
Native Gearhead
Jul 2, 2003 08:44 AM
jrahn
Mar 10, 2003 12:24 PM
speedkingf100
Jan 30, 2003 06:00 PM
