electrical gremlin??
Old Jan 25, 2012 | 03:17 AM
9d4's Avatar
9d4
I have a 1974 f 100, 4x4, 390. I just got this truck 2 summers ago. I am in the process of getting it roadworthy. It seemed to run fine “idling” (because it’s not ready to be driven yet) but then one day I decided to drive it down the road, I got about a block away and it was running terrible, like it had no power and was running super rough, then it quit running all together just shut off. I turned it over it wouldn’t start and the battery was getting low. So I pulled another car up to it and jumped it, it started right up, got it home turned it off it wouldn’t start??? After it sat a while it fired up?? So I figured it was the original brain box. So I found a deal on a pro billet dist and an msd 6a. I hooked it up truck fired right up, and I thought all was good then the next day after I turned it off it wouldn’t start? The next day it started? I put a new volt reg, msd blaster coil on, new battery wires etc. and it still did this I even switched coils it wouldn’t start. After it decided to start again it worked with both coils I have?? Also the ignition switch was replaced. I would appreciate any ideas on what is going on. Thanx
Old Jan 28, 2012 | 06:49 PM
wildcard221's Avatar
wildcard221
and i take it you also checked to make sure the alternator is good and even though you replaced the battery wires...did you check to make sure that the battery wire that actually connects to the bottom of the block is connected right and not loose(it happened to me when i first got my truck i didnt notice it until i started tuggin on wires and low and behold that dirty ground wire was loose LOL!
Old Jan 28, 2012 | 07:06 PM
justforkicks's Avatar
justforkicks
have you changed the plug wires recently? do your plug wires cross paths? follow your ignition wires, you may find one that's bad.
Old Jan 28, 2012 | 07:12 PM
77393's Avatar
77393
I would start from scratch and check every wire at both ends going from the solenoid to the engine and ignition. Is it charging when it is running? Dirty connections can cause alot of resistance. Did you see if you have voltage to the regulator when the key is in the run position?
Old Jan 31, 2012 | 03:58 PM
9d4's Avatar
9d4
I think the ground from the battery is connected to the frame???
Old Jan 31, 2012 | 04:07 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Battery should ground to engine block. Another from engine to firewall. Another ground to frame doesn't hurt.
Old Jan 31, 2012 | 06:29 PM
BIGT94z's Avatar
BIGT94z
Also make sure your grounds are grounded to good metal (clean)
Old Jan 31, 2012 | 07:49 PM
'79Fordpilot's Avatar
'79Fordpilot
If you think it could be an ignition issue, go out at night and start the truck. With the hood raised, watch for any sparks jumping around from your plug wires / plug area. Having someone rev the engine while you watch might also help chase it down. Any sparky type gremlin just might show up in the dark.
Old Jan 31, 2012 | 08:48 PM
77393's Avatar
77393
Good point, we figured out a problem on a old CJ Jeep like that once in our younger days. Either way, if it is missing and you think you got open wires etc, take a spray bottle of water, fire it up and start spraying the plug wires and cap, you will know real quick if you have a cracked cap or a open plug wire. Did you get all the cables and wires cleaned and tightened up?
Old Jan 31, 2012 | 10:36 PM
planehunter's Avatar
planehunter
Bad Battery..............been there.
Fistfull of dollars
16
Dec 26, 2017 11:57 PM
lowcountryF100
Jun 12, 2016 04:57 PM
V10man
Dec 10, 2013 07:02 AM
slayerman54
16
Jan 8, 2012 09:32 AM
mositso
Electrical Systems/Wiring
Nov 25, 2003 11:35 PM
