coolant leak
Old Jan 24, 2012 | 06:56 PM
CR3999's Avatar
CR3999
coolant leak
04 F-350, w/ 6.0
have a coolant leak that starts some where on top of the engine. The coolant runns down the back left side of the engine, and drips off the starter. It doesn't do it all the time. Sometime it only leaks a little and other times it leaks a bunch, and other times not at all. I have crawled under the truck and climbed all over the top and cant't see where it's comming from. Has anyone else had this problem? What am I over looking? I replaced the water pump and the radiater hoses last year. Its not the water pump I have checked it. A bud of mine said to check some hase for the egr valve. Where is this hase at and what size is it?
Thanks Guys<!-- / message -->
Old Jan 24, 2012 | 07:23 PM
69cj's Avatar
69cj
10 to 1 it's the egr cooler hose. Just to the left of the oil filter housing down in the valley. If it's never been changed it's probably an orange hose.
Old Jan 24, 2012 | 09:59 PM
critterf1's Avatar
critterf1
Take a flashlight and look to the passenger side of the oil cooler assy.
Old Jan 24, 2012 | 10:16 PM
hubler13f's Avatar
hubler13f
Also check the heater valve. There is a single philips head screw on the top and they tend to leak around it. It is located next to the passenger side valve cover, directly above the starter.
Mine leaked for months and I was never able to find it, then I read the following post by Jay Bird and figured it out.
https://www.ford-trucks.com/forums/1...with-pics.html
Old Jan 25, 2012 | 12:12 AM
Snuggyworm's Avatar
Snuggyworm
possible egr cooler hose leak. cos if ur egr cooler or oil cooler are busted, they're usually busted internally. they jus wont cool, and u'll see tat hot ticker jumping to the hot zone. it sounds manageable. best of luck man! let us know wat it is or wat u find.
Old Jan 25, 2012 | 12:13 AM
Snuggyworm's Avatar
Snuggyworm
worse case scenario, i might come out to give u a hand if u still need help. i'm only in west houston. lol.
Old Jan 26, 2012 | 06:35 PM
CR3999's Avatar
CR3999
Thanks alot folks! I'll check it out this weekend.
Old Jan 26, 2012 | 07:41 PM
BLADE35's Avatar
BLADE35
Thats a Hell of a good Offer Dom
I tried to rep ya but the rep gods Didnt see it that way
Heres a Good pic of what Dom is talking about
Check right where you see that short orange Hose where it comes out of the Oil cooler and goes to the EGR Cooler
& also the Heater hose towards the Left side of pic it has the Vaccum silinoid on top and that Brass Tee fitting for my coolant filter
Old Jan 27, 2012 | 04:45 PM
CR3999's Avatar
CR3999
Thanks alot for the pic. I looked to today and didn't see anything. Now I know what to look for. THANKS!
Old Jan 27, 2012 | 05:02 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Look right down here:
Old Jan 27, 2012 | 05:03 PM
amdriven2liv
Covered the Reps for you.
Old Jan 27, 2012 | 07:00 PM
Snuggyworm's Avatar
Snuggyworm
thanks guys. it's probably annoying to the OP tat he has tis prob and he cant fix it right there and then. amdriven2liv & benny, u guys are always supportive of all of us six-o's. we need to spread the reps to u as well.
benny, i got the same prob wif the reps too. i gotta spread around some love b4 coming back to u. now who wans some love from the snuggyworm? lmao!
Old Jan 27, 2012 | 07:02 PM
Snuggyworm's Avatar
Snuggyworm
it's the least i can do to give back wat i got from tis forum. if a fellow six-o is in trouble, it wouldnt hurt to have an extra pair of hands and ......... tools! dont forget tools!
Old Jan 29, 2012 | 12:46 PM
CR3999's Avatar
CR3999
Well I found it. It is not leaking at this time, thats the way it goes, when ya want it to leak it's not. I'll think I will replace it anyway. Looks like the best way to tackle this to to take off the pipe that goes to the turbal, if I take that plate off wear the torx screws are at. (front of the hose) Does that whole thing come up.
I have turned a few wrenches before, I replaced the water pump, and ball joint through these forums. the truck has 223,555 mostly trouble free miles. Thanks folks!
Old Jan 29, 2012 | 01:02 PM
BLADE35's Avatar
BLADE35
Thanks Sean I just reped you 2
Dom I will have to catch ya later But was a great offer
To the Problem When your looking for this Leak it would help to have the truck up to normal operating temp and have a little Pressure on the system
Maybe you did IDK just a thought here
