lights pulsating
Old Jan 24, 2012 | 06:24 AM
4601ton's Avatar
4601ton
lights pulsating
I think my original alternator might be giving up the ghost. I noticed today when I pulled up to work my lights seemed to be pulsating ever so slightly. The gauge doesn't seem to be pulsing with the lights. Tried turning off blower motor, no change. Tried turning on blower motor full blast, lights dim and pick back up again...ideas?
Old Jan 24, 2012 | 07:01 AM
Lazy K's Avatar
Lazy K
Check that your battery terminals are clean and tight, check that ALL ground wires are clean and tight where they bolt up.
Old Jan 24, 2012 | 07:20 AM
4601ton's Avatar
4601ton
Alright, will do! Probably is grounds, I know I have one that is questionable, and they're all original.
Old Jan 24, 2012 | 07:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
also pull the wires off the headlight switch and inspect it closely. these trucks are known for burning the light switch and wiring pigtail.
Old Jan 24, 2012 | 07:59 AM
Midnite1987's Avatar
Midnite1987
If you give it a little gas does it even out?
Old Jan 24, 2012 | 11:08 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
THIS!
... and more letters for the forum software..
Old Jan 24, 2012 | 11:21 AM
str8sixman's Avatar
str8sixman
i had a core support ground boogerd up from previous owner, when you turned on the headlights it would shut the truck off
Old Jan 24, 2012 | 12:20 PM
4601ton's Avatar
4601ton
I didn't even rev it up, honestly...I'll try that after work. And I'll check the headlight switch...it, too, is original...
Thanks for helping me keep Daisy healthy guys!!
6.9idiatsturbo
18
Aug 15, 2016 05:54 PM
abe
Jul 30, 2014 07:56 PM
fp60rx
Mar 29, 2012 09:06 AM
johniebomb
Jan 25, 2012 01:07 PM
alvald83
Nov 21, 2010 01:13 AM
