87 ford f150 no injector pulse
Old 01-24-2012, 06:14 PM
LeRoy Coverdale Sr.'s Avatar
LeRoy Coverdale Sr.
LeRoy Coverdale Sr. is offline
up date, truck is alive! found the two ground wires dangling next the the radiator and kinda blended in, so i found them and connected to the battery, fired right up!thank you guys for your help and invaluable insight! and no there was no dead mouse, I know the smell of burned electrical! lol!!!
The following users liked this post:
Old 01-05-2024, 06:18 PM
Evangelion's Avatar
Evangelion
Evangelion is offline
1st Gear
[QUOTE=LeRoy Coverdale Sr.;11332584]up date, truck is alive! found the two ground wires dangling next the the radiator and kinda blended in, so i found them and connected to the battery, fired right up!thank you guys for your help and invaluable insight! and no there was no dead mouse, I know the smell of burned electrical! lol!!![/QUOTE
I am having the exact same issue when I came across this thread. Can you please verify where these “dangling wires” went to that fixed your injector problem please??
Old 01-05-2024, 11:31 PM
Soup bean's Avatar
Soup bean
Soup bean is offline
[QUOTE=Evangelion;21088470]
Two power grounds come out of the harness, to a connector (if it is still there), and should be terminated at the battery negative. If this doesn't solve your problem, you should start your own thread.
In this picture, the two ground wires were incorrectly connected to the O2 sensor harness. They should go to the battery negative.
spurredon
23
03-15-2010 12:37 PM
toddn78
08-12-2007 10:47 PM
JOHNJAY28
10-19-2006 06:23 AM
irishguyincc
1983 - 2012 Ranger & B-Series
03-05-2006 05:32 PM
gaknut
08-13-2004 05:16 PM
Quick Reply: 87 ford f150 no injector pulse
