351w intake ?
Old Jan 23, 2012 | 05:48 PM
trumsey07's Avatar
trumsey07
351w intake ?
maybe u guys can help me out im swapping my 302 for a 351w and the last thing i have to do is swap the factory 2brl intake for a factory 4brl intake i picked up,but my questions is will a holley 650 4brl carb fit on my factory 4brl intake or will i need anadapter? i have the carb on my 302 rate noe but that has an edelbrock performer intake on it any help would be awesome thanks
Old Jan 23, 2012 | 07:16 PM
Franklin2's Avatar
Franklin2
Yes, the factory 4bbl intake has the same bolt pattern as the squarebore aftermarket holleys. It will fit, but you might need a spacer to make it work out, the original carb probably had one for the egr. Holley did make some spreadbore carbs also(big ones in the rear, little ones in the front) so those will not bolt on, but they sell adapters for those.
Old Jan 23, 2012 | 09:49 PM
trumsey07's Avatar
trumsey07
thanks for the info
79flat
Nov 13, 2017 08:08 PM
The Confederate
Sep 13, 2010 11:09 AM
lud04X
Jul 13, 2007 02:56 PM
shotgun_000
Jun 26, 2007 02:29 PM
Ford347
Jul 29, 2006 04:06 PM
