speedometer/transmission/rear abs
Old Apr 20, 2003 | 09:55 PM
tommmy's Avatar
tommmy
I HAVE A 92 FORD 4X4 WITH STRAIGHT 300 6 CYL. YESTERDAY ALL AT THE SAME TIME. MY REAR ABS LIGHT CAME ON,SPEEDOMETER STARTED BOUNCING AND TRANSMISSION SHIFTED HARD THEN BEGAN SLIPPING. ANYONE HAVE ANY IDEA WHAT COULD BE GOING ON?
Old Apr 20, 2003 | 10:20 PM
dro man's Avatar
dro man
replace you rear axel speed sensor, about $15 bucks and give it a test drive.
Old Apr 20, 2003 | 10:48 PM
Ryan50hrl's Avatar
Ryan50hrl
pull the rear diff cover off and change the fluid too....make sure the clutch packs for the limited slip aren't busted up. if they are the metal in there will do all kinds of stuff to your speedo.
Old Apr 21, 2003 | 12:04 AM
steve83's Avatar
steve83
First, check the wiring to that sensor - it runs along the e-brake cable, so it might have been pulled loose.
Old Apr 21, 2003 | 02:18 AM
MustangGT221's Avatar
MustangGT221
The speed sensor controls the ABS and the transmission shifting so they are all related to the same problem. Check the wires like Steve said first. The signal from the rear end to the speedo is a pulse signal, any unteruption in that signal (bad wire) would cause it not to work. If that checks out. the speed sensor ring might have lost a tooth on it, so open the diff cover and inspect it. Check to make sure none of the teeth are damaged. If so, replace it, it's cheap enough. If that doesn't work, it could be the speed sensor on top of the differential.
Old Apr 21, 2003 | 10:47 AM
tommmy's Avatar
tommmy
THANKS FOR YOUR HELP GUYS, I'LL FOLLOW UP AND LET YOU KNOW HOW IT TURNS OUT .
Old Apr 21, 2003 | 04:50 PM
tommmy's Avatar
tommmy
JUST WANTED TO LET YOU GUYS KNOW. I CHECKED WIRING AND LO AND BEHOLD,THE WIRING TO THE SPEED SENSOR HAD BEEN BURNED IN HALF. SEEMS THAT WHEN I HAD NEW EXAUST INSTALLED THEY RAN PIPE AGAINST WIRES. REROUTED AND RECONNECTED.TRUCKS DOING GREAT!! YOU GUYS ARE SHARP.THANKS FOR YOUR HELP.
Old Apr 21, 2003 | 05:28 PM
MustangGT221
Old Apr 21, 2003 | 07:37 PM
steve83's Avatar
steve83
Another fine example of why you should always diagnose a problem BEFORE buying any parts.
