New Excursion Owner
Old Jan 20, 2012 | 07:21 PM
Daewoo's Avatar
Daewoo
New Excursion Owner
I just picked up a government owned '00 XLT 4x4 with the 5.4L, 4.10 gears and a limited slip differential.
It has 172k and every delete package that ford offered. No 3rd row, carpet or rear heat.
I was very happy to get 15.4 mpg over 200 miles today in mixed city and highway driving conditions.
It appears that I have a manifold leak, as I get a tick under load.
At speeds above 30 mph a driveline vibration/growl/whine becomes noticeable and gets louder as the vehicle speed increases. Switching into or out of 4WD does not change the noise. That leads to another thing that puzzles me. The left front hub has no "auto" position and the right one does.
The only other issue is the steering is a bit loose off center and the wheel is turned about 20 degrees to the left when going straight.
Does anyone have any experience with any of these issues? I got a good deal on this unit and look forward to getting it fixed up.
Hopefully I can upload some photos of the new Ex soon.
Old Jan 20, 2012 | 07:22 PM
cpoer's Avatar
cpoer
No comments without pics first
Old Jan 20, 2012 | 08:11 PM
cbradford's Avatar
cbradford
Welcome Daewoo!
You'll find a wealth of information here!
Daewoo's Avatar
Daewoo
It appears that I can't upload pictures until I have more posts??!!
Old Jan 20, 2012 | 08:12 PM
cbradford's Avatar
cbradford
I think the magic # is 25 posts to upload pics, so post away!
Old Jan 20, 2012 | 08:37 PM
Daewoo's Avatar
Daewoo
Old Jan 20, 2012 | 11:31 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
pretty clean looking truck! the 4:10s will def help the 5.4 get you moving!
Old Jan 21, 2012 | 10:21 AM
UrbanXX's Avatar
UrbanXX
To get your steering wheel centered and the play taken out is very simple. Just get the front end aligned and tell them to center the wheel and adjust the slack in the steering grear. It has a "slack" adjustment on the steering gear box.
Some of you guys out there help get Daewoo get started and give him so reps for posting a picture of his EX.
Welcome aboard Daewood.
Old Jan 21, 2012 | 07:41 PM
WE3ZS's Avatar
WE3ZS
Welcome aboard!
Nice EX, mine is a former gov owned also, Army Corps of Engineers. I didn't know 4.10 was an available ratio on the EX's, maybe only on the V-8's? What are the plans for it?
Old Jan 21, 2012 | 08:10 PM
wpnaes's Avatar
wpnaes
For the sloppy steering, try the steering box tighten trick. I'll find the post for ya.
Old Jan 21, 2012 | 11:49 PM
Daewoo's Avatar
Daewoo
I crawled under the front end today and checked the steering components. All is tight except for the steering box. 1.5 inches of play off center before the pitman arm moves. I started the truck 6 times yesterday and today it won't crank. I suppose I will throw in a new starter from DB Electric.
Old Jan 21, 2012 | 11:56 PM
Daewoo's Avatar
Daewoo
Neither of my hubs will disengage and they are very hard to turn. Are they supposed to have slack in them? I am new to the whole vacuum hub deal.
Old Jan 22, 2012 | 12:04 PM
njneer1's Avatar
njneer1
Welcome !
Lots of info on the vaccum hubs on here.....spray the "crack" where they rotate with WD 40 to loosen them up.....you can pull them off and soak them...most guys replace them with manual hubs like Wrn or milemarker premiums......keep an eye on Summit Racing....they put the milemarkers on sale for $99 from time to time....
Mile Marker 449SS - Mile Marker Supreme Locking Hubs - Application - SummitRacing.com
There is a spiral lock kit you will need also.....if you get milemakers I will show you how to get them....hopefully with less problems than I had since I have been through it.
gogreenwave
Jul 30, 2014 05:54 AM
BeavisTheMighty
Jul 8, 2012 11:23 PM
bubbamurr
Jun 25, 2004 06:12 AM
2004FX4Wheeler
2004 - 2008 F150
Mar 21, 2004 12:50 PM
ldgrate
Dec 31, 2003 05:24 PM
