Regular or mid grade
Old Apr 20, 2003 | 04:34 PM
Just Jack's Avatar
Just Jack
Just a simple question. First I'll say I've had older 4, 6, and 8
cylinder engines I've switched up to the mid grade gas from reg.
with no problem but those didn't have a computer brain. A man doesn"t know what will effect these computer jobs.
I have a 96 F150. 5.0. auto., 4x4. Would there be any problem
switching to mid grade gas from reg. The manual says to only use reg.
The valves jabber sometimes when pulling the camper up a
grade. Thanks.
Come on back
Just Jack
1996 Ford F150, 5.0, automatic,
custom wheels, custom bed cover
with hatch, 4x4, lock out hubs,
E.B. edition
Old Apr 20, 2003 | 04:43 PM
Bob Ayers's Avatar
Bob Ayers
Has your "pinging" problem developed over time?? If it has, then
you might want to see what might have changed. Things like a
dirty MAF sensor, carbon build up in the combustion chambers,
or the wrong heat range plugs can cause a "pinging" problem.
If your truck has always done this, then I don't see why it would
hurt to use the midgrade (89 octane) when you going to be doing
some heavy pulling with it.......I have read that using premium
gasoline (93 octane) when it is not needed, can result in excessive deposits in the combustion chambers....
Old Apr 20, 2003 | 07:50 PM
Chas1234's Avatar
Chas1234
I started running midgrade in my '89 (300 I6 ) and I noticed that it excellerates alot better and I get alittle better milage with it .
I say give it a try and see what happens , switch the fuel fiter if it has been awhile !
DerbyPowerstroke
Modular V8 (4.6L, 5.4L)
Jul 15, 2015 02:32 PM
kissfan79
Feb 20, 2014 11:34 AM
jv2290
16
Mar 18, 2011 05:59 AM
gt350h
Sep 7, 2007 02:38 PM
Billll
1997 - 2003 F150
38
Jul 25, 2005 03:50 PM
