High Idle
Old 01-20-2012, 04:55 PM
mr.fordneck's Avatar
mr.fordneck
mr.fordneck is offline
High Idle
So my 1990 f150 5.0 efi has a high idle. Most of the time it idles at 1100 to 1200 rpm. I cleaned the IAC valve. Possibly bad TPS sensor? I thought my throttle was stuck but I doused it in lube and made no difference. Suggestions?
Old 01-20-2012, 05:46 PM
toby tough's Avatar
toby tough
toby tough is offline
You mite check for a vac. leak before throwin' parts at it.I had the same thing awhile back,turned out it was the intake man. gasket. I would also get a volt meter and do some testing on the TPS before you buy another one.There are alot of items that send to the computer concerning idle speed. pull some codes too.
Old 01-20-2012, 09:40 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,193 Likes on 942 Posts
Great suggestions from toby tough. Before going too far, need to ask how long this has been happening? Any parts changed before or other service work?
I also suggest to remove the connector to the IAC, see if the engine idles down. If it does you most likely have a sensor issue. If it remains high start looking for vacuum leaks.
Old 01-20-2012, 11:25 PM
mr.fordneck
[quote=rla2005;11315118]Great suggestions from toby tough. Before going too far, need to ask how long this has been happening? Any parts changed before or other service work?
I had my truck in the shop in October because after they replaced my starter, my throttle kept getting stuck open. They diagnosed it as needing a new throttle body. I'm going to do that repair when I can track down that part but they doused it with lube which i have also done which let the truck idle around 800 rpm. In December, it had problems idling consistently but I cleaned the IAC valve and that solved it but now the truck just idles high and cleaning the IAC valve didn't help. I know I need a new throttle body but this problem is just at idle.....
Old 01-20-2012, 11:26 PM
mr.fordneck
I also replaced the vacuum canister on the passenger side (coffee can) with a non rusted out one
Old 01-22-2012, 08:10 AM
jakehog2's Avatar
jakehog2
jakehog2 is offline
Mine did this when the TPS went bad, didn't throw a code, not sure how to diagnose this. I had a local shop figure it out and hell they put an IAC on first. I imagine the TPS would show voltage out of range from where it's suposed to.
Hope this helps some.
Old 01-22-2012, 10:53 AM
rla2005's Avatar
rla2005
rla2005 is offline
Fuel Injection Technical Library » Throttle Position Sensor (TPS)
Anthonynoble
08-24-2016 04:13 PM
boice1971
10-01-2015 10:03 PM
knlcasteel
10-06-2010 11:32 AM
KMP09
11-09-2007 12:49 PM
tapenick
1978 - 1996 Big Bronco
02-26-2002 07:18 PM
Quick Reply: High Idle
