Gauges reading high
Old Jan 20, 2012 | 11:02 AM
bighatchy's Avatar
bighatchy
Gauges reading high
I have a 73 f100 longbed 390 auto 2wd. All my gauges read high. I checked the resistor wire in the cluster wiring. It reads 12v, which I'm pretty sure is too high. What should it be and what is the best way to fix it?
Daryl
Old Jan 20, 2012 | 01:11 PM
montana_highboy's Avatar
montana_highboy
Faulty ICVR (instrument cluster voltage regulator) when tested it should pulse 5v every second or so.
Old Jan 22, 2012 | 02:22 PM
fmc400's Avatar
fmc400
MSEE
The voltage after the resistor wire (at the ICVR input) won't give you any useful information because the current through it is low and pulsed. Check the voltage at the output of the ICVR as MH suggests; I too suspect it's bad.
You can easily check the resistor wire by measuring the resistance between the ICVR input stud (ICVR removed) and an upstream hot-in-ACC circuit tap.
Old Jan 22, 2012 | 06:30 PM
bighatchy's Avatar
bighatchy
Thanks for the info. I had read a thread a few months ago about somebody asking about rewiring gauges. I remember somebody mentioning that there was something controlling the voltage to the gauges. I just couldn't find it again. I'll be checking into that now
Old Jan 22, 2012 | 09:10 PM
charkane's Avatar
charkane
I had a similar problem with my F150 360fe – the gauges (especially temp and fuel) where reading high and were often erratic…major headlight pulsation too. Turned out the ground wire to the engine had never been reconnected after an engine change (previous owner). Problem solved after reconnection.
Old Jan 22, 2012 | 10:30 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Just so you know where it is located..... It's under this part of the circuit. Attached with connectors like a 9v battery.
Holehawgg
Jun 29, 2014 10:24 PM
alhorgan
Sep 25, 2012 10:18 AM
juchertf100
21
Mar 3, 2012 10:02 PM
02GrayPowerStroke
Mar 2, 2010 12:31 PM
cguard
Apr 10, 2005 01:56 PM
