Engine problems
Old Jan 20, 2012 | 10:36 AM
blazinbronco11's Avatar
blazinbronco11
Engine problems
Last year i put a 351 bored 30 over in my 93 f150. the engine came out of a 92 ford van. the f150 originally had a 302 but i lifted it and wanted more power. The problem with it is that it goes through spark plugs after a few starts. The spark plugs are covered in black carbo soot im assuming. I replaced the injectors, cap and rotor, anything that i could think of.
Anyone have any ideas of whats wrong?
Old Jan 20, 2012 | 10:38 AM
Ole' gray's Avatar
Ole' gray
humm, does it run rich?
Old Jan 20, 2012 | 10:50 AM
Edgethis's Avatar
Edgethis
Are you running the stock SD set-up? Did you do the engine work or have a shop do it? Hows the timing?
Old Jan 20, 2012 | 10:52 AM
blazinbronco11
i believe it is running very rich
i had the machine shope do the boring and everything to the block but i did the rebuilding process
Old Jan 20, 2012 | 10:58 AM
Edgethis's Avatar
Edgethis
Well the stock SD setup will only go so far before freaking out. I would think it would run lean if anything tho...
Are you sure its timing is set right? Does it run smoothly?
Old Jan 20, 2012 | 12:35 PM
blazinbronco11
timing is very close to right on. it may be off a little bit tho. i was wondering if since i bored it, the computer would need reprogrammed?
Old Jan 20, 2012 | 12:40 PM
hivoltj's Avatar
hivoltj
Pull computer codes and go from there.
NVM
I re-read it, you're running a .030 over 351 on a stock 5.0 computer? That's no bueno, not gonna be 100%. Also your old motor probably had non-ho old 302 firing order, and your new one is 5.0HO/351 firing order. Are your plug wires in the right order?
Old Jan 20, 2012 | 12:44 PM
blazinbronco11
it isnt throwing a code
Old Jan 20, 2012 | 12:46 PM
blazinbronco11
i replaced the computer. i got one for a 351 and i used the firing order from the old engine. it doesnt act like it is missing, it acts a little doggy when its cold but other than that it doesnt run bad
Old Jan 20, 2012 | 01:11 PM
88n94's Avatar
88n94
How's your gas mileage?
Old Jan 20, 2012 | 01:57 PM
blazinbronco11
i dont drive it much...its more of a 4 wheeler
Old Jan 20, 2012 | 01:58 PM
Edgethis's Avatar
Edgethis
The 302 and the 351 has different firing orders. The HO 302 has the 351 order IIRC.
Old Jan 20, 2012 | 02:51 PM
SCRebel's Avatar
SCRebel
I am running a 351w bored 40 over on a stock SD EFI.
You have to use the 351w firing order, of course if you didn't, I don't believe it would run at all.
Is it flooding when you try to start it? or starts fine just running rich?
Old Jan 20, 2012 | 03:18 PM
hivoltj's Avatar
hivoltj
It would probably run, just run like ****!
This thread needs one of these!
Old Jan 20, 2012 | 11:13 PM
blazinbronco11
it starts up like any other vehichle, just runs rich and after no less than 10 starts the plugs are fried
