air bag module
Old Jan 19, 2012 | 02:13 PM
sadiejane's Avatar
sadiejane
air bag module
anybody know where the air bag module is located on a 2010 ford f-150?
Old Jan 19, 2012 | 07:24 PM
tvsjr's Avatar
tvsjr
Are you referring to the "brain"? That would be the restraint control module. It's located underneath the center console - in all newer vehicles, this is where you'll find it. The idea is that it should be the last thing damaged in the event of a crash.
Old Jan 19, 2012 | 07:55 PM
Archion's Avatar
Archion
Veteran: Marine Corps
It is reccomended that it is replaced along with the airbags as a set.
Old Feb 2, 2012 | 02:09 PM
sadiejane's Avatar
sadiejane
thanks for the info,it was in the center console,now that i replaced the airbag @ module when i start the truck the airbag light flashes @ wont shut off. how do you reset the light,does it have to go back to a dealer to be reset or can you use a scanner?
Old Feb 2, 2012 | 10:13 PM
tvsjr's Avatar
tvsjr
Count the blinks - typically, there's actually a code, which will tell you what's wrong. Beware, the airbag system is very sensitive... unless everything is perfect, you'll get a light. Typically, the entire supplemental restraint system (all airbags, pretensioners, etc.) is inoperative while the light is flashing/illuminated.
2000Ford2000
Electrical Systems/Wiring
Jun 3, 2013 02:47 PM
Andyriv
Mar 3, 2010 11:44 AM
croozer
Nov 18, 2009 08:55 PM
