isspro ev2 questions
Old Jan 19, 2012 | 12:29 PM
Liquid10Rider's Avatar
Liquid10Rider
Hey guys Im getting the package deal through riff raff for the 3 gauge pillar and next month I plan on getting the F-650 dash kit. Im looking at the coolant temp, oil temp, and rear axle temp gauges. My question is how would you go about puttting the sender for the axle and oil? I already have a spot for the water temp which is on my coolant bypass filter head.
Thanks,
-AJ
Old Jan 19, 2012 | 01:20 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I would suggest fuel pressure long before rear axle temp myself.
Old Jan 19, 2012 | 02:03 PM
Liquid10Rider
How would you go about installing fuel pressure. Like where would you tap into?
Old Jan 19, 2012 | 02:42 PM
riverrat41's Avatar
riverrat41
There is a plug on the backside of the fuel filter housing you can tie in to.
Old Jan 19, 2012 | 04:06 PM
CSIPSD's Avatar
CSIPSD
Oil temp you can remove a plug on the oil filter housing, or there is another plug on the block itself next to the oil filter housing.
You can also tap the HPO res and get the same reading as the PCM.
Rear diff you can weld a bung on the factory cover, drill and tap the 2008 and up rear cover or order one of the expensive covers.
Fuel pressure you will need an adapter (which I believe RiffRaff sells) which goes into the back of the fuel bowl.
Talk to your vendor about the warning lights for the EV-2 gauges... Very handy!
If you have any questions about the Isspro gauges, feel free to PM me.
RyanMac119
May 31, 2019 08:37 AM
czthda
Jun 26, 2013 04:01 PM
Punisher29073
Oct 8, 2012 08:06 PM
jayc3169
Jul 25, 2011 03:26 PM
RussB
17
May 18, 2009 06:31 PM
