Fuel Pressure Test Gauges
Old Jan 18, 2012 | 10:05 PM
JonathanN's Avatar
JonathanN
I've been using an old $17 Liquid-filled Summit gauge on my regulator for about a year and a half. Gauge has worked great, but the fluid inside is leaking out now. So, guess I'll be getting a new one. I need to go back in and redo some of my fuel lines so while I'm in there, guess I ought to do something about the gauge. What do y'all use on your regulated returns? The Aeromotive gauge is twice as much, but so far I've liked everything I've bought from Aeromotive. Also, do y'all mount them on the regulators or mount them remotely? I'd like to scrap the one on the regulator and just run one inside the cab, but it'd make adjusting the regulator a pain. Any input would be great!
Old Jan 18, 2012 | 10:27 PM
woodnthings's Avatar
woodnthings
If you mount it remotely on a piece of flexible hose, you can help isolate it more. The gauges take a pretty good beating from vibration. You can always mount an electric sensor on it and just remove it when you are adjusting the regulator. How often do you adjust it anyway? IMO I would use a fuel pressure test gauge to set it and a sender to a FP gauge in the cab to keep an eye on it the rest of the time.
Old Jan 18, 2012 | 10:39 PM
JonathanN's Avatar
JonathanN
That's actually not a bad idea... not sure why I thought I needed to leave it on all the time. I've just found that every now and then my regulator likes to creep down so it's just convenient if I'm in a parking lot somewhere to not have to put my gauge back on. Instead, I can just adjust it with the truck sitting there running. Guess I could put in a small valve but now it's getting more complicating than it needs to be.
Old Jan 19, 2012 | 09:42 AM
woodnthings
Take a look at Diesel O-Rings.com and his adapters. You can simply install a tee fitting and have both at your disposal. The good part of a cab mounted fuel gauge is you would see your pressure dropping before you had to adjust it in a parking lot. I always recommend isolating the gauge with a flex hose and rubber mounts to keep them from to much vibration. It will make them last much longer.
Here is a schrader valve you can install for quick access to use a FP test tool.
Replacement O-rings for Ford Diesel Engines
Old Jan 19, 2012 | 09:44 AM
JonathanN's Avatar
JonathanN
Didn't even think of that... the OBS trucks had those. I actually have an OBS fuel bowl lying around.
Old Jan 19, 2012 | 10:04 AM
trekbasso's Avatar
trekbasso
Hi, not to hijack the thread but on fuel gauge issues, I just installed one, in the cab.
Uses an electric sensor mounted on the back of the filter bowl.
Any known issues with a set up like this?
Showing 62 psi driving around, okay? Nothing done on the fuel system yet, all stock.
Thanks.
Tom
01 F250 CC 4x4 7.3 204k.
Old Jan 19, 2012 | 10:07 AM
woodnthings
Thanks.
Tom
Yep, that is fine to mount it there. I have mine in the lower passenger port so I see post filter pressure.
Your pressure seems to be normal.
JonathanN's Avatar
JonathanN
Thanks.
Tom
Good stock pressure... very good. Nothing wrong with that setup as I'll be doing the same later on down the line. I'm just trying to figure something out for when I have to adjust my regulator... again, those are good numbers for stock. To my knowledge, you're lucky to get mid 50's stock.
Old Jan 19, 2012 | 11:08 AM
trekbasso's Avatar
trekbasso
Thanks Ken and Jon,
Always curious what is happening under that hood. Know I know! At least part of it.
I was expecting mid 50's. I'll take what I got.
The port I used, driver side, rear, is that post or pre filter? Took out plug with an allen wrench.
Tom.
Old Jan 19, 2012 | 11:12 AM
timmyboy76's Avatar
timmyboy76
Thanks Ken and Jon,
Tom.
that location is pre-filter readings...same plug on bowl, but on p/s, will give you post readings.
Old Jan 19, 2012 | 11:14 AM
JonathanN's Avatar
JonathanN
Good to know...
Old Jan 19, 2012 | 11:28 AM
trekbasso's Avatar
trekbasso
Great to know. Thanks.
Tom.
Old Jan 19, 2012 | 11:44 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by JonathanN
my regulator likes to creep down.
Adjusting the FP regulator may just be making up for some other problem. If your FP keeps "creeping down" it might not be the regulator but the fuel pump, the FPR or something going on with fuel supply. That's why it is advisable to have a FP gauge as a diagnostic tool. Just something to consider.
Old Jan 19, 2012 | 12:56 PM
JonathanN's Avatar
JonathanN
I know what you're saying... thing is, this regulator's done it before (it was free so... you get what you pay for). It might be an old Aeromotive, but I'm not sure. And the thing about it is it's not a slow creep, it'll drop down to 30-40psi. I had to use a metal washer under the locking nut because it kept coming loose with the plastic one that was in there. It would come loose and I'd have to keep adjusting it. Once I replaced the washer with a metal one, I only had it come loose once and that was after a year of running. I've tweaked it some as the temperatures change (the pressure is higher when the fuel is cold), but nothing major until a month or two ago.
Old Jan 19, 2012 | 01:32 PM
PaysonPSD's Avatar
PaysonPSD
Gotcha. But for others still good advise why a FP gauge is a good one to have. Since installing one I wouldn't do without. It's great as an early warning and diagnostic tool.
