2004 navigator
Sitting all the way flat in front and back.
I can remove the relay and jumper the harness, the compressor works.
I bought a brand new relay
Checked all 4 fuses related to suspension.
Check air suspension message is on in the message center. Nothing happens when I start the truck and put it in drive with the doors shut. I don't know what else to look at?
Shot in the dark, but I just read a thread here where a member stated that he had to replace a coupler (I think) under the compressor because the air was not getting to the bags. I'll try and find it.
I can't even get the compressor to kick on. I know the compressor runs, and the relay is brand new... but i can't get it to kick on and the "check air suspension" message won't go away.
I've also tried disconnecting the battery for 15 min or so to try to reset whatever the issue is. I've turned the air suspension switch off and on too.
Oh! My bad, still early. I saw "compressor works" and didn't realize that it worked only when jumped. Is it a common relay? If so swap it with another one and see if there are any changes. I have read of relays being dead even new.
Do you have a reset button under the passenger dash? When mine (1999) has overheated (when I had the coupler noted below go bad) I had to turn off the reset button for a few seconds and flip back on to get the compressor to work.
I have an on/off switch in the cargo area, but I don't see anything about a reset button on the 04. I've done quite a bit of searching and I haven't seen that mentioned for this year model. I WISH it had a reset button!
As long as the check suspension message is on, its not going to make any adjustments. To find out why the message is on, you'll need to have the code(s) pulled to even know where to start.
BE CAREFULL: This IS the most expensive system to maintain out of ALL the Fords & Lincolns since they started this stuff back in '84.
At an average of $800 per corner to stay with the air, I would recommend doing the 4 wheel conversion.....as it would be 1/4th price.
What is involved in pulling the code? Is it something only the dealer can do?
Nathank, seems at this point it is worth having a shop pull the codes to see what's up. I thought on the 04 with the sliding steps it was not guaranteed the light will turn off. That somehow it's integrated and the problem must be rectified. I sure wouldn't do the swap just yet if all else in the esteem worked fine and it just quit running. Have the code scanned and go from there. At least then you will have some direction
Sorry for grammar. On phone.
Nathan, I think Millers had a good point. I had a '99 that had an on/off switch above the passenger kick panel right next to the fuel shut off. I had to turn it off whenever I lifted the truck off the ground. Does the '04 have a master switch like that to engage and disengage the entire system?
And as for the conversion kits leaving the warning light on; I ended up going with Strutmaster coil springs in the rear of my Expy (they were way too soft for my liking) and the kit came with instructions on getting to the computer module under the dash and told me exactly what wire to cut to get the suspension dash light off. As for the system I just pulled the bags out and flipped the switch to the off position.
