So I already have a shackle flip? Is that what u r telling me? I bought the truck as it is the only thing I have done is change flatbeds. What do u fellas think I would need to get 35's under it. I got 31's right not.
I don't know if you have a shackle flip or not... I'd have to see a picture of your rear shackle. The F350 4x4's came with a factory 4" block in the rear, but the rear shackle would be "under" the spring eye. If the shackle is above the spring eye then you have a shackle flip done, but the back end of the truck would sit really high with a shackle flip.
35's should fit fine in the rear if it's stock F350 4x4 height, in the front you might need to trim the bumper and it might rub when flexing/turning sharp if it isn't lifted at all. I'd recommend a 2-3" lift in front for 35's, 33's are fine at stock height.
I got a flatbed so i should be good there. I will take some pics of the rear leafs for ya so u can possibley point me in the right direction. Give me about 2 hrs and I will have pics of the rear up
