All my gauges dont work??
Old Jan 15, 2012 | 05:03 PM
joel79ford's Avatar
joel79ford
None of them work, not even my speedometer it just spins around
the only one that works is my engine temp gauge
I dont know whats wrong???
any help is appreciated
Old Jan 15, 2012 | 05:22 PM
fmc400's Avatar
fmc400
MSEE
When I saw "all my gauges don't work," the first thing I suspected was the instrument cluster voltage regulator (ICVR) - but since the temp gauge does work, then that takes that out of the equation. That means each gauge does not work for a separate reason.
Fuel gauge: most likely a bad sending unit, or ground out at the sending unit itself.
Oil pressure gauge: possible bad sending unit.
Amp gauge: doesn't do anything even when it "works."
The speedometer could be a loose or poorly lubricated cable - does the odometer work?
Old Jan 15, 2012 | 05:44 PM
joel79ford's Avatar
joel79ford
Yea the amp is stuck in the middle it sais ALT- does not move at all
and according to my dad he said that it is an electrical problem??
is that worse??
oh and the speedometer seems to work its just that everytime i stop or hit the clutch it seems to be loopy
Old Jan 15, 2012 | 07:05 PM
ManfredVonRichtofen's Avatar
ManfredVonRichtofen
Make sure your oil sending unit wires is hooked up to the oil sending unit on the engine and up to your cluster.
Old Jan 15, 2012 | 08:50 PM
fmc400's Avatar
fmc400
MSEE
is that worse??
I said in my previous post that the factory amp gauge will not show anything anyway. If it does not move, it does not mean anything. This is because it is a shunt-style ammeter which by design can't display any useful information.
The factory ammeter just goes between D (discharge) and C (charge) - what do you mean it says "ALT-"?
Make sure the speedometer cable is fully seated in the back of the cluster.
Old Jan 16, 2012 | 09:05 PM
joel79ford's Avatar
joel79ford
I checked my fuse box and im missing two fuses
hmm..
Old Jan 16, 2012 | 11:34 PM
fmc400's Avatar
fmc400
MSEE
hmm..
That doesn't answer my question. Help me, help you.
Also...none of the gauges go through the fuse panel. Missing fuses have nothing to do with the issues you're seeing.
75BigBlock
Jun 25, 2017 12:11 PM
PEZLO
25
Mar 8, 2017 01:06 PM
jasonnerothin
Dec 3, 2010 09:07 AM
jimmmack
Nov 20, 2010 09:24 AM
Bdox
Electrical Systems/Wiring
Feb 20, 2006 08:05 PM
