Help PLEASE!
Anyways, I went to take the screws out that hold the dist. cap on, and snap-snap they both break, ok, I wasn't too angry, I went and got another dist from the autozone, checked everything out, looks and feels absolutely identical. I marked where the old one was (AND took a picture of it) before I even loosened the hold-down. Then I dropped the new one in EXACTLY where the old one was, put everything back together, and checked the timing (pulled the "jumper" thing before it). Shows about 60*+ off... can't be possible, so after screwing with it for a while I figure out the damper has to be slipped. The other problem was the EGR valve opening wasn't detected (KOEO code), so after chasing vacuum lines for a while, I by-pass the vacuum reservoir and engine light stays off, hopefully meaning the EGR is working.
ANYways, so I go to drive the truck and now the check engine light is off, but it stumbles under load, about 1200-1600 RPMs, and gradually gets worse until I drop the hammer and force it to downshift. Its odd, when it starts to stumble, the truck has no power to pull out of it, so I barely maintain my speed. It feels like a bad U-joint, the whole truck vibrates, but not violently and the engine doesn't make any weird noises. When it downshifts, its fine above 2000+ rpms (or so it seems). Once it a while it also stumbles at low engine speeds, when I put it in D or R when standing still, but this seems to be only when its warmed up- the lights dim and the charging gauge shows a low reading that bounces around a bit.
What I have done so far: changed timing (seems to make NO difference) checked plugs (all are gapped at factory spec, with no burns, damage, or cracks) tried better plug wires (no difference) pulled dist to inspect for anything wierd (nothing) Chased vacuum lines (no leaks) Hooked the vacuum reservoir back up (no difference) I think the vacuum reservoir is bad, either leaking or the one-way valve in it is bad, but either way, makes no difference.
I can't imagine it being anything other than what I've listed since I haven't touched anything else... and this happened immediately after doing what I listed above... nothing seems to make a difference, and it doesn't show any other symptoms- while its stumbling all the gauges show thier normal readings, the speedo and tach don't jump around, there is no pinging, it doesn't heat up... no funny noises... no check engine light... I've been lurking around this forum and a couple other ones looking for tips and so far everything checks out... so please help me! My last F-150 was a '94 that was identical to this one except it had A/C and the 5.0. That damn truck never broke anything and ran to over 350K!!! Why is this one beating me up at only 77K?!
PS- One thing I did read about is the MAP sensor, they said one symptom is hard shifting... not sure if this is true but my truck does shift a little hard, so I will try unplugging it and driving it like that tomorrow.
Thanks in advance for any and all help... I just want this thing to run right again so I can get to work and back without worries or it vibrating my teeth loose on every hill...
YMMV
rikard
Whats a JY? I'm hoping to keep the gas mileage where it should be- the truck used to get 13-16 mpg which isn't great but with me having to get it revving and downshifting to climb hills (I live in upstate NY so this happens a LOT) its not even doing that, about 10-12 mpg tops which is crazy thats what my '95 3500HD with a 454 gets.... The torque of this engine used to pull me up hills at 12-1500 rpms which was great, because the greatest factor in gas mileage is the driving style, and I'm pretty good at "miser-driving".
I'll try unplugging it and see if it changes anything. If it makes it better a new one will be going on there. I'm gonna try a couple different things today and see if it helps any.
Reps for this.
You change something, it behaves not like you wanted, so CHANGE IT BACK HOW IT WAS.
ctubutis, I have been looking for any dirty or loose connectors with no luck, this thing is pretty clean under the hood for a 16+ year old truck, only corrosion so far is the dizzy and the vacuum reservoir. Most connectors have a little bit of dirt on the outside, but when unplugged the inside is nice and clean.
I tried two things yesterday- The first was unplugging the MAP sensor which did nothing except make it want to stall. I read on another forum that someone was having trouble with it stumbling with no check engine light, and unplugging the MAP made it run good again but now I know thats not my problem.
I also replaced the vacuum reservoir, as the old one was rotted out down on the bottom where I could not see it. I put in a good aftermarket one that is about the same size, leftover from one of my hot rods and it seems to help a little- so after work tonight I'm going to try to see if I can find any more vacuum leaks- it would be great if that was the culprit, nice and easy...
ONE more question- is there any adjustments or calibrations on these distributors? I compared the A-zone one the old one and could not find anything different, except for the broken screws and some dirt and grime. If all else fails, I have had trouble with some A-zone electrical parts before so maybe getting one from carquest and getting my money back on the A-zone one would help...? Or does anyone have a better recommendation on the best place to get an OE replacement dizzy for this thing?
Sorry for writing you guys a couple of volumes here, but this is my first 300 or any straight six for that matter, so I did not know if there was something I was missing... thank you for all the help so far though!
If the timing is too far retarded, it will act just as you say, and not leave codes.
Anyways, I test drove it and as soon as it got into 2nd gear, pinging like a SOB... so I backed off the timing little by little until the pinging went away, and the shaking came back, so I found a "happy medium" to where I could safely drive it, with no pinging and a little shaking (again). I then checked where the timing was... about 2 to 4 degrees ATDC... what the hell? So I filled it with 93 (had 87 in it before) figuring that would help temporarily (only $3-$4 more anyway) and sure 'nuff- I could advance the timing to ZERO with no pinging and no shuddering. I have been driving it a couple of days like this and it just barely pings a little when climbing a steep hill.
I tried un-plugging the MAP, truck would idle rough, but go into gear it stalled out. I guess that's doing it's job.
So next question... would the knock sensor be causing this? Obviously the timing was not set right when I got it, but somehow it ran perfect on 87 and even got about 14 mpg, now I'm lucky to get 12 and can't make it run right... I called a few auto parts places today and they were saying they can't get it and one even tried telling me it doesn't have one because it's not in thier computer... only reason I mention this is I found another thread on a different site where someone was having similar problems with an 80-something F-150 with a 300, combined with a slight "miss" at idle. They were discussing the knock sensor causing it. My truck does this as well, but I can live with that if I can't fix it- the lack of power, mileage, and pinging not so much.
BTW, thanks for the help so far!
Also, you need to remember these engines (or any fuel injected engines, for that matter) don't like to be off very much on the distributor timing. They just won't run correctly.
What that degree is is uncertain, but I would imagine 5 teeth off would be too many.
