Sponsored by: Real Truck
steering wander problems
Old Apr 2, 2022 | 01:40 AM
kris_j77's Avatar
kris_j77
Originally Posted by Kusich
I had a similar problem with my 2004 f250 crew cab. When I turned the wheel and let go it wouldn't return to zero, and it would drift on the road and jerk side to side real hard and fast. So I jacked it up and took my tie rod off. then I used a big screwdriver and put it threw the u joint and rotated it so the yoke was straight up and down (like a plus sign, not an x) then I turned the tire both ways to full extent. It pretty much went where ever it wanted to and and was loose. I then rotated the u joint 90 degrees so the other axis of the yoke is up and down, and repeated the last step. This time it was a little harder to turn the wheel and it didn't move around freely. This meant that the the Bearings on this axis of the u joint was bad I Replaced them and the problem was solved. It increased the handling dramatically and was easier to turn than it was for the last 20,000 miles when I didn't notice any problem at all. And u joints are easy to change and cost about $30. Im only 18 and I had the whole thing tore apart, fixed, and reassembled in 3 hours
we’re you hubs locked doing this?
Old Jun 29, 2022 | 08:18 PM
debski9111's Avatar
debski9111
5th Gear
excursion wandering
I have a 2001 Excursion with the 7.3. I have replaced the steering gearbox, front end bushings, shocks and had it aligned. It has 130,000 miles on it. It is a chore to keep it between the lines at highway speeds. If the road is humped in the middle it handles even worse. It can be unsafe when I am towing my toy hauler down the highway.
I took it to a good frame and alignment shop and he says the bushings in the leaf springs are a bad design. He recommends I replace the spring packs and find some that don't have the stock ford rubber bushings. I am looking for springs with a bushing that has a metal sleeve around it so it will last. Any suggestions out there. Not looking to lift the rig. Thanks...
Old Jul 1, 2022 | 08:44 AM
Tumbleweed1972's Avatar
Tumbleweed1972
[QUOTE=Kusich;15438533I then rotated the u joint 90 degrees so the other axis of the yoke is up and down, and repeated the last step. This time it was a little harder to turn the wheel and it didn't move around freely. This meant that the the Bearings on this axis of the u joint was bad I Replaced them and the problem was solved. It increased the handling dramatically and was easier to turn than it was for the last 20,000 miles when I didn't notice any problem at all. And u joints are easy to change and cost about $30. Im only 18 and I had the whole thing tore apart, fixed, and reassembled in 3 hours[/QUOTE]
This man has got it figured. There are a few guys that have come up with this conclusion. If the truck doesn't get the hubs locked in often then one axis of the u joint can get stiff and when it spins itself in line with the balljoints then it will cause stiff steering and wandering.
regret
36
Jan 13, 2017 06:59 PM
bulldog389
Jun 25, 2013 08:28 PM
jbilliel
Jan 12, 2008 05:38 PM
mustang_gt_350
Jun 1, 2007 10:10 PM
F-150_XL
May 11, 2005 07:17 PM
