Sitting on C
Old Jan 13, 2012 | 04:21 PM
GaSouthern250's Avatar
GaSouthern250
Sitting on C
My bottom right gauge on the dash, water temp I believe, is sitting pretty much on C while I'm driving and going to the middle while idle. Any thoughts?
Old Jan 13, 2012 | 04:47 PM
fixxxer-upper's Avatar
fixxxer-upper
FTE Fan
Have you inspected the sensor, connector, and wires at the thermostat?
Old Jan 13, 2012 | 05:09 PM
utjer's Avatar
utjer
How is your coolant fluid level?
Old Jan 13, 2012 | 05:47 PM
GaSouthern250
Coolant level is a little above max. This is after driving about 2.5 hours. I just went over a mtn and the lever went to between H and C. And sitting idle it's up above the bottom line. Haven't checked thermostat yet because I'm traveling.
Old Jan 13, 2012 | 09:14 PM
PSDlongbox's Avatar
PSDlongbox
stuck open thermostat.
Old Jan 14, 2012 | 02:23 PM
GaSouthern250
Got an idea of the repair cost? I'm assuming a new thermostat is needed.
Old Jan 14, 2012 | 02:29 PM
fixxxer-upper
FTE Fan
Around $20 at Autozone...30 minutes of your time. Remove upper radiator hose, remove thermostat, replace thermostat & gasket, install radiator hose.....done.
Old Jan 14, 2012 | 02:41 PM
GaSouthern250
Do I need to drain at all?
Old Jan 14, 2012 | 03:01 PM
fixxxer-upper
FTE Fan
I would with the coolant level being above max from your earlier post. With a cold engine, I never had much coolant spillage changing them out. Even with the draining added, still less than a 30 minute job.
Old Jan 15, 2012 | 09:12 PM
GaSouthern250
So, this afternoon while driving back home from my trip, my truck got to normal running temps within about 10 minutes or maybe 6-8 miles. It sat between C and H for the next 72 miles until I got home. Is it possible the thermostat became "unstuck" in some sort of way? I'll be monitoring over the next two trips I take to work which is about 18 miles one way. Finers crossed issue worked itself out.
Old Jan 15, 2012 | 09:14 PM
PSDlongbox's Avatar
PSDlongbox
yes it is possible, but I would replace the thermostat. It is cheap and simple to do.
Old Jan 16, 2012 | 08:27 AM
fixxxer-upper
FTE Fan
Agreed! Don't chance having other engine failure due to a $20 part.
Old Jan 16, 2012 | 08:48 AM
GaSouthern250
Ill definitely be replacing it!
Old Jan 16, 2012 | 09:18 AM
69cj's Avatar
69cj
Have you ever had the cooling system flushed? If not now is the time to do it.
1. Drain coolant
2. Add 2 cans of VC-9 and top off with distilled water.
3. Drive 20 to 30 miles, preferably at highway speeds.
4. Drain radiator at petcock first, then pull lower hose. Then remove block plug on driver side. Not necesary to do passenger side.
5. Remove t-stat. To do this, remove air cleaner. Then 2 nuts on t-stat housing. Pry press. sensor bracket off of studs. Tight fit but it will move. Remove 2 more nuts and pull t-stat and housing from studs.
6. Remove t-stat and put housing back on. Re-assemble everything and fill with distilled water.
7. Run at 1200 rpm's for 3 to 5 minutes and drain as described in step 4.
8. Repeat 4 to 5 times or until water coming at is as clear as water going in.
9. Install t-stat using new O ring. I used vaseline to hold the O ring in place.
10. After everything is re-assembled fill with a 50/50 mix of Ford premium gold or Zerex GO-5.
11. Start engine and check for leaks. This is a lot easier and quicker than it sounds. If you don't remove t-stat then you have to run truck between each flush till t-stat fully opens and then let cool down to work on it.
Highly recommend installing coolant filter kit while cooling system is empty. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Old Jan 16, 2012 | 10:07 AM
PSDlongbox's Avatar
PSDlongbox
1. Drain coolant
<o></o>
If you are gonna go through all that I would switch to cat elc instead of ford gold.
