2001 X 4x4 Reworking wheelhubs, axle and autolocks. Vac lines destroyed. Would someone guide me on replacemnet hose and fitting(pref stainless) If you don't know the #s and resource, how about specs/size.
thnx
Reason: Make/model
I/D...just standard 3/16" vacuum line or fuel line. Keep in mind the fuel hose will be stiffer than the lines that are OEM. The line will go through the same route as the ones you take off. Takes about 3 feet per side and will take you all of 3 minutes per side to complete.
