another electrical issue... yet again.
Old Jan 15, 2012 | 12:59 PM
  #31
Franklin2's Avatar
Franklin2
Originally Posted by JJray
Yeah that's what I thought. Could this mean I was given a bad alternator? Or keep looking for more grounds? Or even both?
I posted how you can test the alternator.
Old Jan 15, 2012 | 06:19 PM
  #32
JJray's Avatar
JJray
Well I tested the alternator the way you said and I'm guessin it failed cause the voltage stayed at 11.72ish.
Old Jan 15, 2012 | 07:57 PM
  #33
81-F-150-Explorer's Avatar
81-F-150-Explorer
Unless you have a bad voltage regulator instead of the alternator. That test just say's it isn't charging, it could still be either one of these components.
Did you replace the voltage regulator yet? Some places have test equipment to test them as well. It will surprise me if it's good.
Where the voltage regulator bolts to the fender is how the regulator grounds through it's case. Clean the area around where it bolts to the fender so it gets a proper ground.
If the grounds are good... If the wiring harness is good... If the alternator is good... If the Battery is good... and you are still getting 11.72 volts... Replace the Voltage Regulator.
Old Jan 15, 2012 | 08:04 PM
  #34
JJray's Avatar
JJray
Ill clean em up and see
Old Jan 16, 2012 | 03:19 PM
  #35
JJray's Avatar
JJray
There all good there too.
Old Jan 16, 2012 | 05:17 PM
  #36
Franklin2's Avatar
Franklin2
That test(taking the field wire directly to the battery +) is a good test for the alternator. One thing we have forgotten to mention is the fusible link going to the alternator. You can put alternators in it all day long, and none of them are going to charge if the fusible link is shot(usually is if you have been changing the alternator with the battery connected).
Take your voltmeter, and with the truck off, put one lead on the neg of the battery, and put the other lead on the large "bat" terminal of the alternator. You should get battery voltage. If you don't, the fusible link is bad.
Old Jan 16, 2012 | 10:04 PM
  #37
JJray's Avatar
JJray
Its figured out for now. The voltage regulator was the fix. see how long this lasts.
Milpool
Mar 21, 2016 10:22 PM
lawdogg_78
Oct 14, 2011 08:59 PM
duke72
Jun 8, 2007 08:33 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Oct 22, 2006 09:14 PM
rusty u-joint
3.8 & 4.2L V6
Jan 12, 2005 08:54 PM
