upgrading motor???
It is almost as simple as what you described, assuming that you stay within the same year motor/truck. Same wiring harness, change the computer (needs to match your motor/tranny combo), motor mounts, frame mounts, exhaust y-pipe, radiator, radiator and AC hoses, and power steering lines.
Two things that are kind of a pain, getting the computer out of the firewall, you need to unbolt the inner fender and pull it out that way. Second, is the frame mounts bolt to the crossmember. There are two big rivets that are in the way, you will need to drill them out (this took me by far the longest of anything).
It took me a weekend to swap my EFI 300 for an EFI 351w. If you are buying a used motor, I would suggest doing a little preventative maintenance....rear main seal, valve cover gaskets, oil pan gasket and check out that oil pan. They are infamous for rusting through.
If you want more details, email me at mblouch@enterasys.com
