EVAP routing
Old Jan 12, 2012 | 08:30 PM
82 F150's Avatar
82 F150
EVAP routing
Hello everyone, I've been in the process of hooking up the EVAP on my 82 f150 302 with the motorcraft 2150 carburetor, and can't quit figure it out. Can I get and explaination of how it all hooks up. Thanks Joe
Old Jan 12, 2012 | 09:04 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Are you planning on routing it and all the components the same as the stock configuration? Are you/did you get rid of any components?
Pictures of the vacuum diagram and of the engine bay will help us help you.
Old Jan 12, 2012 | 09:21 PM
82 F150's Avatar
82 F150
Everything is there. Well, see, what I can't figure is the purge valve, (small round green , three ports) I'm not sure which side goes to the pcv and the vacuum.
Old Jan 13, 2012 | 06:57 AM
Franklin2's Avatar
Franklin2
From studying the older diagrams on Autozone's site(seems the newer diagrams don't show the purge valve) the center port is the control port that comes from the carb. Looking at the top of the valve, the left port goes to the connection on the canister, and the right port goes to the suction of the engine(PCV valve in your case?).
What I would do is hook the center port to the carb, and hook the right port to the PCV. I would then warm the engine up and then stick your finger over the left port and see if you have vacuum on it when you rev the engine, no vacuum when idling. If so, I believe it's correct, and you can go ahead and hook the canister up to the left port.
Old Jan 13, 2012 | 07:14 AM
82 F150's Avatar
82 F150
Is there a specific port on the carb to connect to? I've noticed a port behind the carb under the breather plate, it points in the direction of the pcv.
Old Jan 13, 2012 | 07:26 AM
Franklin2's Avatar
Franklin2
I am not sure, they changed this stuff around from time to time. See if you can find a port that only has vacuum when you rev the engine.
chemaholic
17
Apr 3, 2018 08:45 AM
nosehair
Nov 2, 2015 03:07 PM
classic4x4
Jun 16, 2015 09:29 PM
Arno F100
Nov 29, 2008 05:36 PM
dsc
Apr 21, 2004 06:10 PM
