EOT Sensor/resistor
Old Jan 12, 2012 | 05:02 PM
trekbasso's Avatar
trekbasso
EOT Sensor/resistor
Hi all,
I noticed a thread on a different forum, from a couple of years ago, concerning the cold "cackle" noise. One poster said he wired a 9k ohm resistor (switched) across the oil temp sensor and it greatly reduced his cold run noise. His thinking is the change in fuel delivery/timing was the cause. When the motor warms up he switches back to normal.
Has anybody heard of this, done this?
It is fooling the PCM, but what else might happen?
Thanks.
Tom
01 F250 CC 4x4 7.3 203,400.
Old Jan 12, 2012 | 06:29 PM
F350-6's Avatar
F350-6
You don't want to do that. Yes timing, fuel delivery, etc. is affected by the EOT readings, but it is that way for a reason. You may not like the noise, but at least it's not harming your engine.
If you're looking for a safe way to cut down on some of the cold weather noise, unplug the EBP sensor at the base of your turbo pedestal. This will keep the EBPV from being actuated and help with the cold weather noises. It will cause the truck to take longer to warm up though.
Old Jan 12, 2012 | 06:57 PM
trekbasso's Avatar
trekbasso
Thanks. I am getting close to doing the hutch/harpoon, hoping that will help some.
The "jet noise" doesn't happen a lot, it's that friggen rattle/cackle from the cold motor that really bugs me. Still, the ebpv might quit working soon.
Hoping to make the gtg here in Houston (Tomball), and check out a few other trucks.
Tom.
Old Jan 12, 2012 | 07:02 PM
F350-6's Avatar
F350-6
Unplug the EBP sensor for a day and see how you like it. You can always plug it back in if it doesn't make a difference.
Att
Feb 2, 2019 12:46 PM
TSTAD
6.7L Power Stroke Diesel
36
Feb 21, 2016 08:35 PM
Blacknav
25
Sep 20, 2015 07:38 PM
Awitte58
24
Nov 14, 2011 10:01 AM
powerstroke6ltr
1983 - 2012 Ranger & B-Series
Apr 10, 2007 11:17 PM
