PCV Vlave Location
Old Oct 29, 2002 | 02:41 PM
jkgulledge's Avatar
jkgulledge
PCV Vlave Location
Hello,
This might seem like a stupid question, but does anyone know where the PCV valve is located on a 1989 F150 4.9l 6 cyl Ford truck?????? I have a fitting that goes into the valve cover that is stamped "Ford", but there is no place to fit a PCV valve. Any ideas?
Joel
Old Oct 29, 2002 | 04:51 PM
larry derouin's Avatar
larry derouin
PCV Vlave Location
>Hello,
>Joel
Joel: On the 4.9 EFI Engine, the PCV valve is on the back end of the valve cover, under the back edge of the INTAKE maniofold. It's more of a blind job by feel, unless you're REALLY nimble and can get yer head back there enough to see it.
Larry
93' F-150XL SCSB 4x2 4.9, E4od, 3.08 ALL RED!
Old Oct 31, 2002 | 09:18 AM
Carbine's Avatar
Carbine
PCV Vlave Location
Joel-
I switched mine out by removing a front wheel and going throught the wheelwell. Still was a drag though!
Old Oct 31, 2002 | 10:32 AM
Redneckerson's Avatar
Redneckerson
PCV Vlave Location
Old Jun 23, 2013 | 01:30 PM
1drummer's Avatar
1drummer
91 F150 4.9..found the pcv and it rattles, but there is a nozzle for a smaller hose and no hose attached..is that normal? my issue is I am getting oil in my breather compartment, enough that it leaks onto the wheel well and to the ground.. I replaced the foam filter in the breather compartment, and I replaced the "cap" that the garden sized hose attaches to. behind the "filler cap" ...under load( in gear) I get a rough idle..
Should I replace the PCV anyway even though it rattles loudly?
Is there a second vacuum hose? for the smaller nozzle?
My $400 4 year old (for me) f150 I bought from the original owner is annoying me....
I can put up with the squeaks, creaks and groans and appearance in public, but only if it acts like it runs good...and does not leak oil in weird places..believe me it has started conversations....
"hey Dude, why is your fender leaking oil?"
chuck7300
Sep 6, 2008 02:38 PM
BAJI26
Mar 16, 2008 01:24 PM
paisano341
Nov 19, 2003 08:00 PM
Webslinger
Oct 5, 2003 12:46 PM
jkgulledge
Oct 29, 2002 05:08 PM
