oil everywhere
Old Jan 10, 2012 | 07:20 PM
bobbj's Avatar
bobbj
oil everywhere
ive narrow down the appx location where im getting oil leaking from and going all over the engine bay. I'm pretty sure its coming from the top of the dipstick. it seats good but everytime i check its out a lil bit. Sooo, where can i get as close to oe as possible? or is aftermarket better?
Old Jan 10, 2012 | 07:40 PM
Barkin 40s's Avatar
Barkin 40s
its not the dipstick its your lack of a properly working PCV system, i would look at pcv valve first and go from there
Old Jan 10, 2012 | 07:45 PM
Anafiel's Avatar
Anafiel
Agreed!
Old Jan 10, 2012 | 08:18 PM
bobbj's Avatar
bobbj
thats beem replaced already, when i shut off i can see oil drippin down the side of tube
Old Jan 10, 2012 | 08:55 PM
Gary Lewis's Avatar
Gary Lewis
You still have pressure building up inside the engine and it is finding its way out the dip stick. The PCV system is supposed to bleed the pressure off, so it cannot be functioning properly if oil is being forced out the dip stick tube.
Old Jan 10, 2012 | 09:02 PM
Anafiel's Avatar
Anafiel
I agree again, unless of course, you are constantly up on two wheels, drivers side down. THAT would cause oil to gush out the top of the dipstick, I would think.
My wife would kill me if I drove like that...
Are you married?
Old Jan 10, 2012 | 09:15 PM
Gary Lewis's Avatar
Gary Lewis
Are you married?
Not for long!
Old Jan 10, 2012 | 10:08 PM
Barkin 40s's Avatar
Barkin 40s
a proper pcv system consists of a good pcv valve,and a oil cap that breathes, the goal is for the smoke and oil mist gets caught in with the air being sucked from pcv valve through the breather and goes into the pcv vacuum port on the manifold
Old Jan 11, 2012 | 01:01 PM
bobbj's Avatar
bobbj
well i checked today and the pcv rattles good and material inside brather cap was ok (cleaned anyways). Maybe build-up inside line from pcv to manifold? it wont hurt to check i suppose
Old Jan 11, 2012 | 02:56 PM
Barkin 40s's Avatar
Barkin 40s
chech if the port on the intake is sucking
Old Jan 11, 2012 | 03:56 PM
Archion's Avatar
Archion
Veteran: Marine Corps
Worst case scenario is there is too much pressure inside for even the pcv to handle ie:blowby.
Old Jan 11, 2012 | 04:04 PM
Stangrcr1's Avatar
Stangrcr1
Hole in piston? Broken rings?
How does the engine run? When running, take off the oil fill cap and tell us what happens.
Old Jan 11, 2012 | 09:15 PM
Brad_81Ford's Avatar
Brad_81Ford
When the vacuum line to the PCV has dry rotted off, my truck would expel the pressure out through the dipstick. It never came off, but it certainly unseated itself from that 'clicked in' position. Never any oil, however.
Old Jan 11, 2012 | 10:03 PM
Barkin 40s's Avatar
Barkin 40s
wouldent hurt to do compression test on all cylinders. ive had a moter run fairly good with two pistons that had holes blowed through them
TexasTornado66
Feb 25, 2022 02:29 PM
alconk
29
Jan 18, 2009 05:21 PM
BrentusBrutus
1978 - 1996 Big Bronco
Jan 20, 2005 12:08 PM
bryan78f1504x4351mc6A
Jul 16, 2003 11:06 PM
pikiluvi
Jun 6, 2003 10:39 AM
