has anybody dealt with this co.lately? i would like to add there interceptor scan gauge with my x monitor. on there web site there is no phone# tech. questions are referred to there tech forum that looks like its been inactive for over a year, e-mails to there sales come back as can't deliver.makes me kind of leary dealing with them.i know the scan guage 11 will do most of the same things, just looking for a little cleaner install,or if you got one for you're 6.0 some where else? thanks for any input
my brother had one in his srt-4 and now he got a supercharged mustang he loves it, he kept telling me to get it, but i was in the market for the scangauge at the time. it has my curiosity, this is what i found it can monitor
Visit our Technical forums at http://aeroforcetech.com/forums for more assistance in
choosing parameters and setting up this Ford Universal gauge.
Platform 2 parameters (Powerstroke):Power Stroke edition including bidirectional controls for injector buzz and cylinder are included in standard version.
1. INTAKE AIR 2- Intake Air Temperature taken at the throttle body inlet
2. COOLANT TEMP 2- Engine Coolant Temperature
3. RPM 2- engine Revolutions Per Minute
4. MANIFOLD PSI 1- Manifold Air Pressure (psia) for voltage based MAP sensors
(mid 1990’s trucks).
5. Manifold PSI 2 – Manifold Air Pressure (psia) for frequency based MAP sensors 6. BOOST 1 – Boost Pressure in psig for voltage based MAP 7. BOOST 2 – Boost Pressure in psig for frequency based MAP 8. MILES PER HOUR 2- Miles Per Hour 9. TRANS TEMP 1- Transmission Temperature for 1998 and newer trucks 10. TRANS TEMP 2 – Trans temp derived from the trans temp sensor voltage for 1997 and older trucks. 11. TRANS VOLTS – Transmission temperature sensor raw voltage. 11. RUN TIME MINS- engine run time since last engine start. Can be used as a trip timer.
12. BATTERY VOLTAGE- Alternator/battery output voltage
13. PULSE WIDTH- injector pulse width in msec. 14. ENGINE OIL TEMP 15. EX. BACK PRESS – Exhaust back pressure 16. ICP DC – Injector Control Pressure Duty Cycle 17. ICP – Injector Control Pressure 18. INJ. TIMING – Injector Timing Deg BTDC
19. CURRENT GEAR – Current Transmission Gear
the thing that i am really interested
Has high intensity warning lights that can be set using a 1 or 2 parameter algorithm. P1, P1 or P2, P1 and P2. For example, trigger the lights when rpm exceeds 6000 rpm, or when trans temp exceeds 230 F and coolant exceeds 210 F, or when air fuel ratio is above 12.5 and throttle is above 75%. Due to the gauges extremely fast update rate, this light is very accurate and easy to set. Once you try it you'll find you can't live without it!
thanks ill call 'modern performance' tomorrow am. and see if they can get one for the 6.0 I'll let ya know, aeroforce might be fine,just don't feel comfortable dealing with someone who you can't get a hold of. online or otherwise
