Sponsored by: Real Truck
Installing larger adjustable track bar on 99EB
Old Jan 9, 2012 | 04:08 PM
barhopper901's Avatar
barhopper901
I'm wanting to install one of the Zone Adjustable Track Bars on my 99 early build.
I understand that I will need one of the later model frame brackets to mount it to. Wondering how those of you who have done this have mounted the track bar to the axle. I found one thread where someone described modifying the Skyjacker TB-920 lower bracket to accept the larger bolt, but was wondering if it was possible to simply modify the existing hole to work without spending another $100.
Any tips or suggestions from those who have successfully done this?
Old Jan 9, 2012 | 05:27 PM
99f350sd's Avatar
99f350sd
I drilled it and ground it to fit the newer track rod...The ford one..
Old Jan 9, 2012 | 08:56 PM
charbaugh's Avatar
charbaugh
You could check out this link: Ford Superduty Track Bar Repair Kit
This is an aftermarket replacement bracket for the axel side mount. You will have to cut off the old one first, though.
Old Jan 9, 2012 | 09:29 PM
barhopper901
Great! This is what I wanted to hear. The other link is very interesting too, but involves a little more work than I'm willing to do at this point. Just wanted to be sure that it was possible to make the larger adjustable bar work. Thanks!
Old Jan 9, 2012 | 09:58 PM
99f350sd's Avatar
99f350sd
Like I said I used the stock larger bar. It wasn't adj but you should get it to work..
Old Jan 10, 2012 | 01:41 PM
barhopper901
Just curious, did you do the same with the upper frame mount hole or did you get the later model bracket?
whitesaige
Nov 25, 2017 07:05 PM
bigblueexcursion
Jul 12, 2016 07:07 PM
justblowin'smoke
Mar 11, 2009 02:08 PM
Sagegrouse
Feb 6, 2005 07:55 PM
mizzitch
Dec 6, 2004 07:29 PM
