Cracked manifold... Replace with headers?
Old Jan 10, 2012 | 12:12 AM
minnesotafisherman's Avatar
minnesotafisherman
Thanks everybody for the feedback, info, etc. I appreciate the help! I don't know when I will get anything done for the exhaust, it is a near-future thing I would like to get done, it's just a lack of funds due to lingering work needing to be done on the truck that is more important. I will post back here with what I finally went with when that time comes.
Old Jan 10, 2012 | 01:29 AM
TexasGuy001's Avatar
TexasGuy001
Originally Posted by minnesotafisherman
Alright. Thank you for the information!
The Thrush Turbo mufflers don't sound too bad:
f-150 true duals - YouTube
I found a set of Pacesetter's for about $270... and I could get a set of Flowtech's for $150.
Are Flowtechs any good? Considering it would save me $$$..
Those don't sound too bad at all.
Old Jan 10, 2012 | 01:53 AM
minnesotafisherman
Yeah, TexasGuy, those are the mufflers I think I will end up getting once I get the $$$ for everything to be done at once. Doesn't sound annoyingly loud, and it's not too quiet either, right in between.
Old Jan 10, 2012 | 07:04 AM
cadillacmob's Avatar
cadillacmob
Originally Posted by TexasGuy001
When I get around to running true dual exhaust on mine, I'm going with Dynomax ultraflo welded. They are sometimes called race magnum.
My truck currently has magnaflow on it and its nice, but a bit too mellow.
I've had different series of flowmaster on various vehicles, and I'm done with the hollow tin can sound and droning.
As for headers, I may go with JBA. If not I'll just get the Summit branded Pacesetter shorty headers.
i have the summit branded pace setter shortys, they worked out very nice
Old Jan 11, 2012 | 12:52 AM
TexasGuy001
Thanks for the added vote of confidence in them.
Old Jan 11, 2012 | 01:14 PM
cadillacmob
No problem. And you can't beat the price on them. They were just on sale for 179
Old Jan 11, 2012 | 01:34 PM
Beechkid's Avatar
Beechkid
With headers, I would highly recommend ensuring the head plate is at least 3/8" thick, otherwise warping & gasket leaks are going to be an issue.
With mufflers, I have used allied units for many years (30+), almost every muffler shop has them, they are a straight through design, flow every bit of any "Performance Muffler", costs about $40-50 each, come in a variety of sizes/lengths, have a nice rumble on accel & decel with a very deep tone.
Old Jan 12, 2012 | 03:52 AM
TexasGuy001
I agree with that comment about the 3/8 instead of 1/4 inch flanges. Thats another reason I got the JBA headers for the Mustang.
Old Jan 12, 2012 | 03:53 AM
TexasGuy001
Definitely on that.
Old Jan 15, 2012 | 06:10 PM
jmtmt's Avatar
jmtmt
One possibility(sp?) for cracked manifold is plugged cat, manifold overheating. Pace setters on sale for $179 where ??
Old Jan 15, 2012 | 08:19 PM
Bob_91SC4x4's Avatar
Bob_91SC4x4
I went with replacing the stock manifold...oops...shoulda done headers.
Old Jan 16, 2012 | 05:31 AM
octaneforce's Avatar
octaneforce
did you decide to do long tubes or shorties? shorties seem better for every day drivers. the long tubes make it hard to get to your starter and will require more modification to your original exhaust. power difference shouldnt be that noticeable, again, this is a daily.
Old Jan 16, 2012 | 09:34 AM
  #28
mpc07005's Avatar
mpc07005
If you do LT's the Pacesetter 70-2221 are reported to have the best fitment on our trucks, and consistent quality. They're 3/8, and the easiest installation. Others have issues with the tranny cross. If you go shorties, you might as well ditch that factory Y-pipe while your're at it, little more work, little more money, but ready for a cam swap to make power (or MPG's).
-Mike
Old Jan 16, 2012 | 09:55 AM
  #29
minnesotafisherman
Well, a majority of people say to go with long tubes.. so that will probably be what I end up going with.
Originally Posted by mpc07005
If you do LT's the Pacesetter 70-2221 are reported to have the best fitment on our trucks, and consistent quality. They're only 3/8, but the easiest installation. Others have issues with the tranny cross. If you go shorties, you might as well ditch that factory Y-pipe while your're at it, little more work, little more money, but ready for a cam swap to make power (or MPG's).
-Mike
Thanks for the info.. I was considering a true dual over the stock y-pipe.
Old Jan 16, 2012 | 10:58 AM
  #30
Edgethis's Avatar
Edgethis
True duals are not worth the effort on our 4wd trucks. With as many bends as it takes. The best option is a good mandral bent single exhuast ~2.5"-3"
