Clunk when releasing brake in reverse?
Apr 18, 2003 | 10:06 PM
When I back up in my 77 F-250 it makes a loud clunk every time I release the brake. I think it's the front right brake catching but why would it only do it in reverse? Any suggestions?
Apr 18, 2003 | 10:29 PM
Please use descriptive titles...
What type of brakes do you have?
2WD / 4WD?
Axle type?
Need Info! -We ain't mind readers...
Apr 18, 2003 | 11:39 PM
Sorry, guess I was brain-dead
It is 2 wheel drive with front disc brakes. The brake in question was rebuilt a few months ago due to 3/8+ inch grooves in the rotor.
(oops) The brake pads had worn through. I hope the clunk doesn't have anything to do with the steering.
Apr 18, 2003 | 11:48 PM
Radius arm bushings?
Here I thought it was a Drum brake truck.
Did you replace the caliper at the time?
Apr 18, 2003 | 11:49 PM
WHERE is the clunk coming from, front or back?
Apr 18, 2003 | 11:51 PM
I determined that the calipers were good so they were not replaced. The noise comes from the front.
Apr 20, 2003 | 11:04 PM
I took the wheel of today and discovered that a rubber bushing has rotted off causing that disturbing noise. Thanks for the help.
Apr 20, 2003 | 11:10 PM
Which rubber bushing was it or where was it?
Apr 21, 2003 | 12:14 AM
I couldn't describe it in words
so I attempted to take a picture a minute ago in the pitch black. It's blury but you can see it.
Here it is
Apr 21, 2003 | 12:29 AM
Those are called the radius arm bushings.
Apr 21, 2003 | 12:59 AM
Yep, just what I thought it sounded like! -hehe
Been there done that...
It should steer a lot better now and wander less.
A good repair manual would help. Best money you can spend on your truck.
Apr 21, 2003 | 08:09 AM
HI-HO ~~~
Ouch!!...that picture hurts just to LOOK at it!! Good luck - let us know how it goes after replacing your bushings on the radius arms...
Apr 23, 2003 | 01:58 PM
I replaced them yesterday.
New ones seen here. The truck rides and steers much better now. Thanks for the help.
Apr 23, 2003 | 02:11 PM
Hi Ho - thanks for the update - that looks much better!! Did you have to get the front end re-aligned? Did that take care of all the wheel slop?...
