67 F250 Highboy core support
Old Jan 8, 2012 | 10:54 AM
hrscrazy796's Avatar
hrscrazy796
What core support can I use for a 67 highboy? Is it the same as a regular 67-72 even though the frame is narrower? And where can I find the best one?
Old Jan 10, 2012 | 03:19 AM
moonley's Avatar
moonley
All 1967-1972 frame widths are the same. Frame widths changed in 1973 and 1977 I think, but even then it was rear of the cab.
Depending on where you are you should be able to get one out of a junkyard. Pretty sure a 73-79 core support will work as well if you can find a good one at the right price, but it may require some minor midifications.
Old Jan 10, 2012 | 03:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by hrscrazy796
What core support can I use for a 67 highboy? Is it the same as a regular 67-72 (depends on which radiator it has) even though the frame is narrower?
The so-called narrow frame has nothing to do with the radiator support, since all 1965/79 F100/350 frames are the same width from the front...thru the cab.
Narrow frame has to do with the width between the inner frame rails behind the cab, which is 33 1/2" for all 1965/72 F100/350's, 1973/77 F250 4WD's (High Boys) and 1973/79 F350's on the 140" wheelbase.
1973/79 F100/350's except as noted above have 37 1/2" rear frame rails.
1967/72 F100/350: There are TWO different radiator supports.
The difference has to do with...if the Super Cooling Radiator (SC/R) is present. Since the SC/R is higher, the opening radius is larger and the mounting holes for radiator flanges are in a different location.
All 1967/72 F100/250 4WD's & F350's came with the SC/R as standard equipment.
1973/77 & 1978/79 F100/350's with round headlamps: The radiator supports are different than 1967/72, and again, there are TWO different supports because the SC/R was also available in these trucks.
1967/72 F100/350 "as original."
C7TZ-16138-A .. Radiator Support / Obsolete / 3 available NOS
Applications: 1967/72 F100/250 2WD-Use with standard, Xtra Cooling & A/C radiators.
C7TZ-16138-B .. Radiator Support / Obsolete / 2 available NOS
Applications: 1967/72 F100/250 2WD with SC/R / 1967/72 F100/250 4WD & F350.
Radiator measurements: Standard, Xtra Cooling & A/C radiators: 26 1/4" wide x 19 1/4" high / SC/R: 26 1/4" wide x 24 1/4" high.
Old Jan 10, 2012 | 09:29 AM
hrscrazy796
Thanks guys great information I'm sure you'll see me ask alot more questions with the 67 highboy we are restoring and stuffing a 429 in it
Old Nov 5, 2020 | 07:07 AM
JensenF250's Avatar
JensenF250
Reviving an old thread - 1967 F250 Core Support
hey guys - looking for one of these. Seeing them on eBay, but also see ND said there were 3 NOS somewhere. If anyone has a lead on a NOS or one in good shape, please let me know. In Indiana I can’t find anything decent in the yard. Have to replace mine as rust on the bottom lip really can’t be fixed.
Old Nov 5, 2020 | 07:31 AM
JensenF250's Avatar
JensenF250
To add, have the 4X4 so I’m needing the C7TZ-16138-B. I did call a dealership ND suggested in another post and they had a NOS but it was $1250.
Old Nov 5, 2020 | 08:14 AM
kenny nunez's Avatar
kenny nunez
Core support
Check with Dennis Carpenter. I bought one and the fit was good and had no problem bolting every thing back together.
AlsRyd66
28
Jul 10, 2025 03:33 PM
cbquinn66
Feb 24, 2017 06:24 PM
jammeyer
WTB - Parts & other
Jan 7, 2015 01:13 AM
Tomcat45
May 13, 2010 08:22 PM
flyboy2610
Paint & Bodywork
Jan 2, 2002 08:47 PM
