Tip for removing king pins
Old Apr 18, 2003 | 05:25 PM
51dueller's Avatar
51dueller
Here's a tip for removing king pins without a press. All you need is a grinder. You have to remove the brake drum first. Grind the head edges so there is no lip. Now beat the head with a BFH it should go flush with the spindle. Spray some lubricant(ex. WD-40) in the locking pin hole. Flip the axle over beat it with a BFH and punch (drift). The king pin should now come out. Volia you have just now removed a king pin. Now repeat for the other side.
Old Apr 18, 2003 | 08:44 PM
pcmenten's Avatar
pcmenten
I would add that if you have penetrant, Liquid Wrench or PB Blaster, that would work even better than WD-40.
Old Apr 19, 2003 | 12:59 PM
51dueller's Avatar
51dueller
ex = example
I used WD-40 as an example.
