Should I change all hoses
Old Oct 25, 2002 | 04:21 PM
gasman6674's Avatar
gasman6674
Old Oct 30, 2002 | 03:27 PM
Shaine_89f150's Avatar
Shaine_89f150
I am going to change the timing chain and both gears, the water pump, the thermostat and the radiator. Now I am also changing all the gaskets as well. I had a pretty bad coolant leak so this is where I am starting to eliminate front end problems. I do know the rad. was leaking so hopefully it stops when I am done. Here is my question The truck is an 88 F-150 with 350,000 km. Do I also change top and bottom rad. hoses as well as the small thermostate hose or should they or could they be tested. Any advise on any part of what I am going to do would be greatly appreciated. Thanks....
Old Oct 30, 2002 | 03:35 PM
genspot's Avatar
genspot
Changing the hoses is cheap insurance... I'd change 'em all, including the heater hoses and manifold heater hoses if your truck has them.
Rob.
Old Oct 30, 2002 | 07:04 PM
PATS2002's Avatar
PATS2002
DO all of them (cheap insurance) heater hoses too!! it's all apart now it's real easy.
Old Oct 30, 2002 | 07:35 PM
Avanti's Avatar
Avanti
Change them all. That small by pass hose by the thermostat is a killer if it ever pops when you are on the road. They are hard to determine if they are bad before they blow apart on the freeway.
Old Nov 1, 2002 | 12:15 AM
Hit Man X's Avatar
Hit Man X
Yes, do it. I changed all mine about two months ago and glad I did. Many were hard as rocks.
I put on Goodyear High-Milar hoses on there. They are great. Have a nomex lining and should last 5x longer than other hoses.
