General Automotive Discussion
reappearing codes
Old Jan 6, 2012 | 08:21 PM
84-250's Avatar
84-250
reappearing codes
2k cavalier 2.2L 185k miles
Code p0133 came up, replaced precat O2, plugs and wires. Code was cleared, car ran smooth. 3wks, several hundred miles later Im getting p0133 and p0141. Car still runs good.
I havent checked the postcat O2 for power to the heater yet.
I dont know what would cause the O2 to have slow responce.
Old Jan 17, 2012 | 07:33 PM
Phinxter's Avatar
Phinxter
P0133 the o2 could have been contaminated by excessive oil consumption, coolant leaking into the combustion chamber or non sensor safe silicone sealant finding its way into the combustion chamber.
p0141 The way I test this is connect a test light to the heater circuit and start the engine. if it flashes or stays on steady the circuit is ok, replace the sensor, but figure out why the other one failed for p0133 or you'll prolly be right back where you started.
Old Feb 25, 2012 | 12:07 PM
84-250's Avatar
84-250
I cleared codes and its been fine since I last posted. Last week I get a P1137 code. Which means low voltage during power enrichment. Thats the downstream O2, correct?
Old Feb 25, 2012 | 03:31 PM
Phinxter's Avatar
Phinxter
yep #2 would be downstream. O2 sensors are subject to harsh environment being in an exhaust stream and all. I have access to live data so I could say either the sensor is bad or not, but most likely thats what it is. Rockauto has good prices on these.
Old Mar 23, 2012 | 07:27 PM
84-250's Avatar
84-250
well they're back again, P0141 and P1137. Do these codes have anything in common?
Bonus, the codes come with a leaking radiator too
Old Mar 26, 2012 | 07:44 PM
Phinxter's Avatar
Phinxter
yeah the thing they have in common is they both point to the after cat O2. Is it the original? I'm surprised it lasted that long.
sweetace1
Apr 24, 2014 06:43 AM
ssullivan
Aug 17, 2008 05:35 PM
bigwillie
13
Jul 3, 2006 12:28 PM
frog73
1978 - 1996 Big Bronco
May 15, 2005 11:26 AM
tankhokie
Sep 15, 2003 08:28 PM
