Modular V10 (6.8l)
Found an electric fan setup
Old Apr 18, 2003 | 03:20 PM
V10KLZZ71S's Avatar
V10KLZZ71S
Called JDM Engineering and asked them about their electric fan for a lightning and said they could slightly modify the shroud to work on a Super Duty V10 $455, should free up 20-40 hp.Checked a Flexalite set up- $540. Still cheaper than a cyclone.
They also have a more effecient water pump that they recommend
that will free up about 5 hp, it is designed different since it doesnt have to spin the fan anymore- $105. The fan uses all Ford parts.Just a little info for yall. Im interested !
Old Apr 19, 2003 | 10:22 AM
V10KLZZ71S's Avatar
V10KLZZ71S
I was mistaken on HP, 15-18 hp, 2 mpg.
Old Apr 19, 2003 | 05:06 PM
jaxf250's Avatar
jaxf250
Interesting.... any drawbacks to the electric fan vs. OEM setup, other than another tap off the elec. system? I realize it prob. only runs when needed via thermostat. Just curious what others think... thx V10KLZZ71S!
Edit: drawbacks isn't the right word... I guess I mean what other things to consider when replacing the OEM unit with an electric one should I know about.... thx.
Old Apr 25, 2003 | 07:06 PM
brew1's Avatar
brew1
Yes, I'm interested! I don't think you normally need that fan turning. Especially when driving down the road with plenty of air blowing throught the radiator. What is costing $500? That seems like a lot to me. Is this including install, or just for parts? Let me know.
2000' F250 LB V10 6" lift 35" AT's
Old Apr 26, 2003 | 04:25 PM
203008581's Avatar
203008581
I'm with you!!!! What?.....a fan costs $500!!!!!! This is BS!!!!! I like the idea and the possible advantages.....but not at that expense.
Old Apr 28, 2003 | 07:53 PM
HeavyAssault's Avatar
HeavyAssault
Thumbs up Found an electric fan setup
I'm running the FLEX-A-Lite 290 fan in my truck. This is their universal truck fan. I have several pic of the setup. The kit includes an auto temp sensor to turn on the fan. I paid $350+ for the fan plus $20 for the brackets I had made to mount the fan.
Old Apr 28, 2003 | 08:07 PM
rabidsnowmobiler's Avatar
rabidsnowmobiler
Seems like a cheaper alternative to the cyclone for those with a little installation imagingation... And now the big question: Did it make a difference?
Old Apr 28, 2003 | 10:05 PM
Forced34795's Avatar
Forced34795
I wonderin gas well if you noticed a performance gain. Also what temp does the sensor trip the fan?
Old Apr 29, 2003 | 12:04 AM
HeavyAssault
I first noticed the accleration lag is gone. The engine will reach higher RPMs faster and smoother. I like the overall driving and feel I got my moneys' worth. I havn't been driving it due to being deployed overseas. I'm hoping to post more info on MPG in the future.
The fan has a control unit that you can set. Using a small screwdriver you can turn the adjustment to where you want the fan to come on. If you have a temperature gague to check while adjusting you will know your exact setting. It is very quiet sitting inside. You will notice the running but the more I drove it the more I got used to it cycling.
If you sit at a long light it will cycle, but in stop-in-go traffic the fan rarely comes on.
I saw the clearance price and couldn't pass it up.
Any questions please ask.
Ford79
25
Jun 28, 2007 08:02 PM
nuts4hotwheels
Dec 6, 2005 12:51 AM
ttb29
Modular V10 (6.8l)
20
Dec 16, 2004 04:54 PM
V10 junkie
Modular V10 (6.8l)
30
Jan 23, 2004 09:24 PM
Chuck
Dec 13, 1999 03:31 PM
