Sponsored by: Real Truck
Mud Flaps
Old Jan 5, 2012 | 09:24 AM
Rose Clifford's Avatar
Rose Clifford
Mud Flaps
I just put a 2012 bed on my 2003 and want to get some decent mud flaps. I want ones that will protect the lower rear of the bed behind the wheel wells, so extra wide would be good.
Should I DIY or does anybody have a good recommendation?
Old Jan 5, 2012 | 09:30 AM
msgtg's Avatar
msgtg
I've put the stock Ford OEM flaps all around on mine and I don't seem to catch a lot of crud in that area of the bed since they've been installed. The bonus was not having to scrape the crud off of the running boards too!
Joe
Old Jan 5, 2012 | 09:32 AM
Rose Clifford
Joe
The stock ones are too small. I have 295/75/16
Old Jan 5, 2012 | 09:40 AM
msgtg's Avatar
msgtg
They make a set for the SDs...that's the set I have on mine. I'm running pretty stock tires on mine...265/75/16s and they do well.
And, the price was reasonable.
Joe
Old Jan 5, 2012 | 09:46 AM
Rose Clifford
I know, that's what I have now.... They don't do well enough
Old Jan 5, 2012 | 09:58 AM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Beautiful Truck!!!
Old Jan 5, 2012 | 10:06 AM
Rose Clifford
Thank you, I'd like to keep her clean if I could! I might just get a set of generic flaps and bolt them on. I'd like a +12" wide set with a FORD emblem though...or a Powerstoke badge...
Old Jan 5, 2012 | 10:32 AM
Eatonpcat's Avatar
Eatonpcat
That is a sweet ride...But the flaps you have on there now look ridiculous!! LOL
Old Jan 5, 2012 | 10:33 AM
Rose Clifford
THANKS! hahaha I know, hence the thread! You should see her now....she has a 2012 bed on her as of Friday. I want to keep it clean and protected.
Fuggit...I'm going to buy some online and just make it work
Old Jan 5, 2012 | 02:48 PM
SuperDutyScaler's Avatar
SuperDutyScaler
I just bought the 14 inch wide front and rear Duraflap's. the front fit beautiful with no problems, the rears on the other hand didn't. the holes were about 3/4 of an inch too far out plus the bottom hole was an 1" too low to even line up. Since i wanted them a little tighter inwards i simply drilled new holes and mounted them were i wanted them. Ifi knew thisi would have saved 12 dollars and bought the undrilled ones and drilled my own holes the first time instead of having three extra holes now that mud leaks through!
Old Jan 5, 2012 | 03:36 PM
Rose Clifford
Duraflaps look perfect. Not cheap though...
Old Jan 5, 2012 | 03:51 PM
SuperDutyScaler
yea i bought the 14" wide no weight ones to keep the cost down, but i wish i bought the no drilled rears because of the problem i had with the holes not being right. But i might cut some aluminum and just polish it and make my own weights for free maybe...
Old Jan 5, 2012 | 07:03 PM
Rose Clifford
So you regret not getting the weighted ones? Do they flap around on the highway?
Old Jan 5, 2012 | 08:44 PM
Trophy_23's Avatar
Trophy_23
I just put on the 14" wide Duraflaps with weights and they are great. I had the OEM molded flaps and they were ok, but with my 325's they didn't protect a whole lot. Duraflaps are expensive, but worth it IMO.
Old Jan 5, 2012 | 08:50 PM
SuperDutyScaler
no you dont need the weights at all, the flaps are a hard rubber almost plastic and they dont move. Im actually worried if i get stuck hunting they wont bend and they might bend the fenders instead
