need help with brakes.
Old Jan 4, 2012 | 08:14 PM
68playtruck's Avatar
68playtruck
My 97 f150 had been sitting for a while and after driving it a few miles I could smell hot brakes and the left front rotor was very hot. So I pulled the caliper to see if I could free it up. With a C clamp I can compress 1 piston and the other one comes out and visa-verse but I cannot push both in at the same time using 2 C clamps. When I push the brake pedal both pistons extend but will not push back in together. Its acting like theirs a check valve in the line. How should I go about trouble shooting? thanks.
Old Jan 5, 2012 | 05:54 AM
stuart1's Avatar
stuart1
The flex hose could be restricted and not allowing fluid to return to the master cylinder.
You can try cracking the bleeder and see if it will return. If so the hose should be replaced.
idstumped
Nov 23, 2017 10:22 AM
jorge995
1997 - 2003 F150
Nov 26, 2012 02:19 PM
68playtruck
Jan 5, 2012 05:57 AM
vinman46
Mar 25, 2004 08:09 PM
dynamic
13
Nov 21, 2001 09:38 PM
