4.9 ticking
Old Jan 4, 2012 | 07:09 PM
rangergirl94's Avatar
rangergirl94
4.9 ticking
My 93 f150 4.9 started ticking today but goes away when it warms up its got 202,000 miles oil change is due should I worry or just change oil and drive? Should I switch to synthetic?
Old Jan 4, 2012 | 07:11 PM
Ole' gray's Avatar
Ole' gray
sounds like my truck, except its just my fan rubbing on the shroud. it stops after a little while driving.
Old Jan 4, 2012 | 08:56 PM
octaneforce's Avatar
octaneforce
theres alot of controversy over the whole synthetic thing. some may say that the thinner synthetic oil will clean out the crud that could be holding your engine together and leak out of worn gaskets. personally, i never use synthetic in my truck. is the oil level low? change the oil and see what happens. maybe sneak a little oil stablizer in there, too.
Old Jan 4, 2012 | 09:07 PM
UNTAMND's Avatar
UNTAMND
Before you change the oil, put a can of seafoam in the oil and run it for about 20-30 miles.
Change the oil to 10-30 and see how it sounds. It's getting cold out so a little ticking at startup is ok. But ticking until oil is 80-100 degrees is a little worrisome.
If it still ticks after 100-150 miles or so then add a quart of marval mystery oil (it's ok for it to be overfull a little) and run it like that for a while. It won't hurt it any.
Old Jan 4, 2012 | 10:21 PM
86F150302's Avatar
86F150302
Checked for exhaust leaks??
Old Jan 4, 2012 | 10:54 PM
Big_Foot's Avatar
Big_Foot
This!
I have NEVER owned a 300 that didnt have an exhaust leak.
Old Jan 4, 2012 | 11:33 PM
rangergirl94
Does leak at manifold/downpipe
Old Jan 4, 2012 | 11:52 PM
Big_Foot's Avatar
Big_Foot
Had 2 with cracked exhaust manifolds and one that leaked at the manifold/collector connection.
Old Jan 5, 2012 | 01:00 AM
JoePhoto's Avatar
JoePhoto
Mine's ticking right now because the A.I.R. Manifold tube has two cracked pipes coming off it, but it ticks at all temperatures.
Old Jan 5, 2012 | 07:48 AM
hotrod351's Avatar
hotrod351
i had gotten the same noise from my 4.9 years back. i put some of that rislone i believe its was. anyway the ticking went away. next time i changed the oil i added it again. ive changed the oil a few time since and havent added any and its still quite.ive used synth oil since i bought my truck, it better oil, and my truck doesnt use any oil so i figured why not use the better stuff. ive got 175 thousands on mine.
macguy
6.7L Power Stroke Diesel
18
Sep 24, 2013 09:59 PM
waterboy_fishing
Apr 13, 2013 06:50 PM
mblanken881
Nov 24, 2011 09:36 PM
crew66
Jan 31, 2010 10:35 PM
ZZZzzzz
2004 - 2008 F150
Mar 16, 2004 08:23 PM
