engine break in stand wiring critique
Old Jan 4, 2012 | 10:19 AM
jniolon's Avatar
jniolon
old and in the way
got my break-in stand nearly complete... some plumbing to do. Most of the wiring is complete now... throttle is mounted in the red slot and all the gauges and meters are installed
just wanted to get a few gurus to look at my wiring diagram and see if I've included any major blunders or if you have any suggestions for changes...
thanks
John
article will follow when time permits
Old Jan 4, 2012 | 10:29 AM
sdetweil's Avatar
sdetweil
looks good..
I am doing that setup to start my new engine as test until I get the wiring run.. no gauges, and the fan isn't mounted yet. (radiator not mounted yet)
my On and Start are all one switch (std keyed ignition switch)
Sam
Old Jan 4, 2012 | 10:37 AM
52 Merc's Avatar
52 Merc
Looks good, John. My only suggestion would be to perhaps run the hot lead to the fan switch independent of the main switch. That way, if you wanted to continue running the fan after shutting the engine down, you don't have to turn the main switch back on to do so.
Old Jan 4, 2012 | 10:49 AM
jniolon's Avatar
jniolon
old and in the way
dang Sam... you should have built it first and I could have borrowed yours !!
good idea Wayne.... that's just one wire to change
john
Old Jan 4, 2012 | 10:55 AM
sdetweil's Avatar
sdetweil
john
but my 'stand' is a whole 56 truck chassis and body!
Sam
Old Jan 4, 2012 | 11:11 AM
4tl8ford's Avatar
4tl8ford
How about a big red push to kill switch on top of the control panel
Old Jan 4, 2012 | 12:21 PM
jmadsen's Avatar
jmadsen
Looks good. All you need now are tires.
Old Jan 4, 2012 | 12:38 PM
HT32BSX115's Avatar
HT32BSX115
Yeah...."me too" but the Electrical Engineer in me would force me to go to an appliance parts shop and buy a simple thermostat-switch (or an adjustable one) and use it to operate the fan so it will always come on when needed and shut off when not! Just "hot-wire" it directly to the A+ (BATT) !
Don't forget fuses and/or circuit breakers!
Cheers,
Rick
Old Jan 4, 2012 | 12:41 PM
jniolon's Avatar
jniolon
old and in the way
so Rick ??? what would you fuse...??? the fan ??? what else
Old Jan 4, 2012 | 12:47 PM
Randy Jack's Avatar
Randy Jack
Geez, what a show-off!
I broke in my engine in the truck, like Sam did.
But, I can hardly wait to see the do-over!
Old Jan 4, 2012 | 12:51 PM
HT32BSX115's Avatar
HT32BSX115
"fuse" all the low current circuits. 10A or less. use a separate fuse for the radiator fan. (it'll probably be a 50A or so?) there's really no way to fuse a starter but you can fuse the starter relay (solenoid control side of it)
I would use the following fan control for the fan and maybe use it for the truck when you get ready to install it...
Flex-a-lite 31147 Flex-a-lite Adjustable Temp Control Switch
It's only about $30
Old Jan 4, 2012 | 12:56 PM
sdetweil's Avatar
sdetweil
Wait.... you mean he is going to have a second break in stand??
why am I helping him with the first one?!!..
I had to break in my engine twice too.. once with bad assembly..
once better..
folks here suggested/convinced me (twisted my arm, ouch!) that a dyno run would be a/the good way..
and it sure worked perfectly..
but I didn't get a freakin breakin stand out of it!..
sam
Old Jan 4, 2012 | 01:17 PM
jniolon's Avatar
jniolon
old and in the way
you don't come around for months... then it's just to scrape the scab off and get it bleedin again, huh RJ ??? I hope there won't be any do overs on the engine... I would break mine in on the frame, but that's another problem... I'll let Sam tell you about so you can scrape some more
Sam, I'm considering a dyno run... after breakin... if the $$$ are available, it'll give me something to do while I"m stretching the frame up front
Wayne, there are only two real circuits... ignition, fan. The lighting circuit is just three 12 volt gauge bulbs. Inline holders wouldn't hurt probably... It's not like we're gonna run this thing up to 2K and go have a cup of coffee... the throttle probably won't leave my hand. Plan A... see smoke, hit the kill switch... Maybe Penn Dick had the right idea.
there is also an outside change of a box fan hanging in front of the radiator
later
john
Old Jan 4, 2012 | 01:39 PM
sdetweil's Avatar
sdetweil
I was lucky, I found a guy that charged me only $250 for a whole day.
9 runs, including the breakin run.
Sam
Old Jan 4, 2012 | 01:40 PM
jniolon's Avatar
jniolon
old and in the way
don't think I'll find a deal like that around here... $$$ I hear is 400 and up depending on time on machine and setup time
j
