Sponsored by: Kumho
Lifting rear slightly
Old Apr 18, 2003 | 10:08 AM
sandrat's Avatar
sandrat
I'm putting a new rear axle in my 91 1/2 ton, and I figure that as long as I'm under there, I should lift it a little. I've got a 2 inch leveling kit in the front, and now the rear is actually a little lower the front. What would be the better way of lifting the rear abut an inch or two; helper springs or get about a 4inch block and remove the stock block?
Thanks, Robert Werner
Old Apr 18, 2003 | 10:20 AM
RRMike's Avatar
RRMike
How big is the stock block? It would probably be cheapest to get one a little taller and longer u bolts.
