rocker stud help
Old Jan 3, 2012 | 08:07 PM
trumsey07's Avatar
trumsey07
rocker stud help
had a buddy accidently pull some of my rocker studs loose on my 351 and i was wondering if anyone knows if there is kit out there to convert these to the screw in style studs?
Old Jan 3, 2012 | 08:48 PM
Anafiel's Avatar
Anafiel
Best to have a machine shop do that. The holes where the studs were needs to be drilled and tapped. You don't want all those cast iron shavings fallin down the oil return holes, so it's best to remove the heads and have them done correctly.
So, how do you "accidentally" pull the studs??
Old Jan 3, 2012 | 09:10 PM
trumsey07's Avatar
trumsey07
i have the 351 on a stand got it ready to put in the truck he was setting the valve i walked over and he was using a half in drive on the valves and he said uhhhh the rockers wont get any tighter
Old Jan 3, 2012 | 10:04 PM
Anafiel's Avatar
Anafiel
Ouch!
bigdan1979f-250
Jan 31, 2010 07:40 PM
kellar
Apr 20, 2007 05:04 PM
hookin'78
Apr 10, 2004 08:16 PM
Scouder
Nov 13, 2003 01:34 AM
BlueOvalRage
May 21, 2002 10:29 PM
