F1 Fender Question
Old Jan 3, 2012 | 02:39 PM
old_dan's Avatar
old_dan
F1 Fender Question
Can anyone post a pic that shows the front fender, cab, and running board alignment?
I installed my front clip last weekend. It has fiberglass front fenders. They seem to be pretty low in the back. On my F2 parts truck, the fenders end at the running boards. It looks like my glass fenders are going to dip below the running boards. Since this is really an conversion of an F2 into an F1, I don't have any "before" pictures as a reference.
Thanks!!
Dan
Old Jan 3, 2012 | 03:30 PM
badger_hound's Avatar
badger_hound
Here's a couple photos of mine. Should be the stock f1 setup... the running boards more-or-less line up with the front and rear fenders. Not the greatest angle but hope it helps:
Lemme know if you need a better picture as I can probably take some closeups later this afternoon/evening.
Old Jan 3, 2012 | 03:49 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Dan, who made your glass fenders? I had the same problem with mine, but only on the driver's side. It was a full 2" below the RB. Personally I thought it was caused by them pulling the fender out of the mold too quickly. Mine are Gibbons.
I tried adjusting with all the bolts loose, no joy. Finally, I put a jack under the rear edge and just shoved it up, drilled thru the RB edge and bolted it. I expected to hear that awful >>CRACK<< noise, but just got some creaking.
Before and after, you can see how much better it matches the lower edge of the hood.
Old Jan 3, 2012 | 03:50 PM
old_dan's Avatar
old_dan
Thanks....that pretty much shows what I was concerned about. I guess mine just look funny without the running boards in place.
Dan
Old Jan 3, 2012 | 03:57 PM
old_dan's Avatar
old_dan
Mine are from Bebops....they fit perfectly up front. In the back, the corner around the cab isn't a perfect contour...and the backs of the fenders look low. But then...my ride height is really low...I'm going to raise that back up a couple of inches.
I was thinking of adding a bolt through the fender to the cab to suck them in a little. That might not be the best idea because the cab is designed to move around. The odd thing is that the fenders are hard bolted to the running board which is solidly mounted to the frame, but the whole front clip can move relative to the frame.
Old Jan 3, 2012 | 04:07 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Yeah, it's a great design, isn't it?! Where I bolted to the running boards, I made the hole oversize and used large washers on each side, with thin rubber pads under them.
Old Jan 3, 2012 | 04:37 PM
GreatNorthWoods's Avatar
GreatNorthWoods
Here's my F-3 to F-1 conversion using Bebops fiberglass fenders and running boards. Guess the alignment depends somewhat on the truck...
Old Jan 3, 2012 | 06:06 PM
mytbtruck's Avatar
mytbtruck
Mine was an F3 converted to an F1. Front and rear fenders and running boards from Bebops. We did some work on the front fenders to get them to fit better around the headlights. It was not to bad to get them this close.
Old Jan 3, 2012 | 06:40 PM
coopdagook's Avatar
coopdagook
boy that is pretty paint and a old flat head rolling around in the bed. lol think I would have drug it behind that truck. I get nervous with the dogs in the back of mine and its not half a pretty as yours.
Old Jan 3, 2012 | 10:21 PM
52 Merc's Avatar
52 Merc
Don't do that. As you noted, Ford designed the fenders the way they did for a reason. While there's a lot of places one can improve the fit and finish on these old trucks, sticking a bolt thru the fender into the cowl to close up that gap is not one of them. Leave that alone and use the rubber filler that's supposed to be there for that purpose. The front end needs to be able to float and pivot on the 2 bolts at the bottom of the radiator support to keep from tearing itself apart when the frame flexes. The bolts at the bottom of the fenders at the running boards are there to keep the fenders from dragging on the ground.
Old Jan 3, 2012 | 11:00 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Gee guys, i just relized how bad my steel fenders fit. Thanks, another thing for my list of things to do, im goin backwards, again.
Old Jan 4, 2012 | 08:08 AM
preppypyro's Avatar
preppypyro
I gotta quit checking out threads with pictures in them, these trucks are too damn nice, and I have about 3 projects to do before i get to mine!
Old Jan 4, 2012 | 08:41 AM
ALBUQ F-1's Avatar
ALBUQ F-1
LOL, my bed is the original old POS and gets used, no trailer queen there. Looks good from 20 ft, tho.
Old Jan 4, 2012 | 11:21 PM
51phil's Avatar
51phil
I have the same problem. I didnt notice it until I already had the drivers side drilled and bolted then went to do the passengers side. Now I am thinking that in the 4 years it was being worked on (up the lift-down the lift) that the running board bracket may have gotten pusthed up a little. My front fenders and running boards are steel. The rear fenders (glass) seem to sit too high on the bed and dont line up with running boards like they should. Hence, I have not bolted them together yet. So now this is a winter repair project. You can see my truck in my gallery.
Old Jan 5, 2012 | 10:45 AM
old_dan's Avatar
old_dan
I'll have to see how it looks when I get the running boards on and bolt up the lower part of the fender. It looks like I really need to get my hood in place to give me something to align the fenders to as a starting point. I'd rather have a good hood to fender line even if it means that the back end of the fender sticks out below the running board. As far as that gap goes, it sits a half inch out, but it only takes a little push to get it to close the gap...I do have rubber seals. It may close up when I bolt the fender to the running board.
Phil...that is a sweet truck....since the front is pretty low...do you have any concerns of the front tires hitting the fenders in a turn. Now that everything is coming together on mine, it is lower than I thought it'd be, so that just sitting there, the tires are inside the fender line. If I raise the front by 2 inches, there is clearance, but it still looks risky when the wheels are turned.
Dan
