one too many wire.
Old Jan 2, 2012 | 10:05 AM
shotgun2's Avatar
shotgun2
one too many wire.
Hi guys,
I got from Number Dummy
1965/74 Econoline & F100/350 240 I-6 / 1965/96 F100/350 300 I-6 / 1969/96 Econoline 300 I-6 / 1980/96 Bronco 300 I-6
F2TZ-11002-A (replaced: E4TZ-11002-A, E3TZ-11002-A, E1TZ-11002-A, D7TZ-11002-A, D4TZ-11002-D, C5TZ-11002-D, C5TZ-11002-A) .. 240/300 Starter-Use with M/T.
So i purchased the correct starter...(and yes when it come to electrical, i was handed the short end of the stick)
well, it has an extra lead on it.... black.
so where do i connect my starter cable.... where the lead is or the other connector???
Thanks
G
Old Jan 2, 2012 | 10:13 AM
OldStyle's Avatar
OldStyle
Rusty Roller
Can you post a pic of this "extra" wire? The starter should have one post for the starter cable. I can't picture what you are refering to. Never seen a extra wire....
Your starter looks like this; correct? http://starterpros.com/Result.asp?IDNum=9769
Old Jan 2, 2012 | 10:20 AM
shotgun2's Avatar
shotgun2
hi
it used to look like that.
but now it look like this. with an extra "S" connector.
Starter Motor (Ford) - China Starter, Starter Motor, Auto Starter in Electric Motor
i bought mine from CARQUEST>
Old Jan 2, 2012 | 10:39 AM
fmc400's Avatar
fmc400
MSEE
That new starter is a PMGR mini starter. It has a solenoid mounted on the starter itself. It can be made to work with some wiring changes. But it's not the OEM style starter. The parts store gave you the wrong starter.
If all you're wanting to do is replace your original with the factory style and not have to mess with anything else, you'll need to take that back. The one shown in OldStyle's picture is the correct type (no solenoid).
Old Jan 2, 2012 | 10:41 AM
shotgun2's Avatar
shotgun2
Thanks
Old Jan 2, 2012 | 11:21 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The OP in another thread...asked for the Ford part number for a 1978 F100 300 I-6 starter w/a 3 speed manual trans.
Since the 1978 part number had been replaced, and had replaced previous part numbers, I listed all the part numbers and their applications.
Old Jan 2, 2012 | 11:25 AM
shotgun2's Avatar
shotgun2
Hi Bill
I know, I was not expecting and extra lead /wire.
G
rwriccitelli
Nov 19, 2015 12:22 PM
thunderbolt427
Nov 24, 2011 12:43 AM
the ford man
May 4, 2010 11:01 AM
minishtr
Oct 7, 2004 09:53 PM
