Coolant leak-need help identifying part
Old Apr 17, 2003 | 11:07 PM
TallGuy_Az's Avatar
TallGuy_Az
96 Explorer, there is a vaccuum controlled valve on the hoses that go to the heater core, about a foot and a half from the fire wall. What is this valve for? It leaks coolant when the vaccuum pulls the valve up, when I disconnect the vaccuum hose, it quits leaking. I have to take it on a trip tomorrow morning, and was wondering if it would be ok to leave it disconnected until I finish the trip. Quick help would be greatly appreciated.
Thanks
Old Apr 18, 2003 | 12:55 AM
TallGuy_Az's Avatar
TallGuy_Az
OK, answered my first question alone. It is the heater control valve. So if I disconnect the vaccuum, everything should be fine until I get a new valve, right?
Old Apr 19, 2003 | 03:18 PM
cobra413's Avatar
cobra413
just replace the valve I bought one about three months ago cause the valve was leaking on my spark plug wires and caused a check eng. light. The valve cost me $15.00.
Old Apr 19, 2003 | 09:08 PM
fordfool2's Avatar
fordfool2
The 3-way vacuum controlled valve is the heater core bypass. It bypasses flow to the heater core when in air conditioning mode.
Old Nov 20, 2003 | 02:35 PM
mightypizu's Avatar
mightypizu
I'm also having this problem and want to replace the heater control valve. Seems fairly straight-forward but will it leak coolant everywhere once I take the hoses off? Any tips?
Thanks.
Old Nov 20, 2003 | 06:39 PM
ejonn's Avatar
ejonn
For MIGHTYPIZU
The valve is at the highest point of the water system.....some but very little fluid will come out.
