Minnesota Chapter Join Chapter, Leader: fordpower88
It's 2012 already??? BS Thread
Old Jan 23, 2012 | 12:35 PM
  #1486
msmenne17's Avatar
msmenne17
Have fun plowing Troy! Will this at least earn you some $$$?
Old Jan 23, 2012 | 12:36 PM
  #1487
msmenne17's Avatar
msmenne17
Originally Posted by Ford79
I am sooooooooo sick of working on $h!+.................
Needed to replace the flex hose on one side of the van and of course the hard line was seized to the nut, twisting it while trying to remove it. Tried to flare a new end on it and broke the stem of the flare tool off in the line.......... Removed line and it is super heavy duty line and has a different flare at the top. UGHHHHHHHHHHH.........
Going to call around tomorrow and see if I can find a new hard line at a dealer somewhere....
I feel your pain! Sounds like working on my vehicles. Absolute crap.
Old Jan 23, 2012 | 12:39 PM
  #1488
DieselCamper01's Avatar
DieselCamper01
I would love to go Tom but i don't know when I can. This coming weekend is booked already. Not sure on the next.
Old Jan 23, 2012 | 12:41 PM
  #1489
MisterCMK's Avatar
MisterCMK
Originally Posted by msmenne17
Afternoon everyone! I don't really want to be at work today. I guess that is what i get for coming in on a Monday. ugh.
Got the truck started last night when I got home. It didn't want to start with out a boost but it started. Charged it for a while last night but didn't want to start this morning. Now that it snowing and raining I'll charge it overnight and see. I'm going to stop at Oreilly andsee if they have a set of Motorcraft GPsnin stock. I know a few are out. May as well do the rest of them too. That ought to help. Block heater needs help but I'm not ready to do that as I have to drain the block. What a pain ...
Actually, you will probably be surprised how much coolant you don't lose replacing a block heater. Keep the radiator cap on and sealed and get ready with the new heater. Remove the old one and install the new one. You shouldn't lose a ton of coolant.
  #1490
fordpower88's Avatar
fordpower88
Originally Posted by Excursion4X4
Good Morning Troy! Sounds like a busy day!
Yeah so far it has been!
Originally Posted by mndiesel
Anybody ready to go to the UP yet?
Hey Tom! It would be fun.
Hey Michael! Good luck getting the glow plugs. Glad it at least started for you.
Nope plowing my own driveway doesn't pay so well!
Old Jan 23, 2012 | 12:42 PM
  #1491
MisterCMK's Avatar
MisterCMK
Tom, call me this afternoon when you get a chance.
Old Jan 23, 2012 | 01:09 PM
  #1492
msmenne17's Avatar
msmenne17
It's not so much the amount of coolant as the mess it will make.
Old Jan 23, 2012 | 01:59 PM
  #1493
MisterCMK's Avatar
MisterCMK
It really isn't that bad. Make the swap quick and you don't loose much because the system is sealed. It has to suck in the air to replace the coolant through the same hole.
Old Jan 23, 2012 | 02:59 PM
  #1494
DieselCamper01
Good afternoon gang. Been a busy day so far playing catch up.
Old Jan 23, 2012 | 03:11 PM
  #1495
msmenne17's Avatar
msmenne17
It's from all that work you didn't do last week while you were having fun at home with Lynn instead.
Old Jan 23, 2012 | 03:37 PM
  #1496
DieselCamper01
Ugh. That was sooooo boring having to be available all that time. Don't get me wrong I had no problem taking care of Lynn but I wasn't comfortable leaving and doing errands just in case. Or hanging out in the garage even. Only so much reading and daytime TV a person can take.
Old Jan 23, 2012 | 04:54 PM
  #1497
Jbotto's Avatar
Jbotto
Well there is a plug that you have to remove on the transmission on the HHR and then pour fluid in until it comes out the hole. Let it stop draining out the hole and then that is it. Effin GM...
Originally Posted by wildstang
Hate to tell you this but ford does it also. A friend had a mid 2000 explorer with no filler tube. Got to fill it through the drain hole by pumping it in
Yep, that's how mine is... I guess Ford did this back in the day too...or maybe it was just for manuals back then. Who knows!
Happy Monday everyone!
***oops, wrong quote of Chris's. No tranny dipstick for mine, filler hole is full when it leaks out of it.
Old Jan 23, 2012 | 05:02 PM
  #1498
Ford79's Avatar
Ford79
That's normal for a manual trans Jake, as far as I know anyway.
Old Jan 23, 2012 | 05:49 PM
  #1499
Jbotto's Avatar
Jbotto
Kinda thought that too Mike. How goes it today?
Old Jan 23, 2012 | 06:34 PM
  #1500
dlibson's Avatar
dlibson
Evening guys. Well, I made it through the day. A bit sore and stiff, but nothing like last week...
