NY's 2012 New Year BS Thread
#991
How many miles are on it??
You may be replacing it for nothing if it doesn't get abused..
#994
I've got just over 66K on it, mileage wise I know it doesn't need to be changed. I'm changing it out b/c of its age and the fact that it's a bit foamy, has me concerned that there is some water in there.....
#995
I use black for things like that. The reason being, it tacks up faster than blue or red, plus it handles the heat so much better.
#999
thats scary frank....heres a link, its for a superduty but it should serve you well.
Welcome to guzzle's Rear Differential Maintenance Web Page
#1001
When I had my axle seals replaced the Ford garage used a sealant on my rear diff. cover.
Still bumming around the house as it is now up to 31*, but still have a wind chill in the upper teens.
#1002
My lappy is saying 26* right now, but those temps come from the Brookhaven Lab, which is on much higher ground. We normally will be 4-6 degrees colder then that.
#1003
Good afternoon, New York. I caught a break in between afternoon jobs.
John, when I had to go into my 1/2 ton differential, I purchased a gasket to go with the new cover. A stinking, messy job none the less.
Good luck,
-JR
Good luck,
-JR
#1005
Besides being pissed that it only lasted 23 years...
I got the truck up on stands on Sunday during the sunny part of the day. My wife was handing me tools so I did not need to crawl in and out. Tried to use the dead blow hammer while she attempted to start the truck. No joy.
Then I decided that the starter had to be removed. So, she fed me the tools while I was under there. I spent almost an hour on it, and I could not get the bolts to budge; even after spraying them. When my hands became numb, I gave up.
I removed the stands, and had the wife and kids push me into the street. Got it pop started down the hill, and took it to a shop. It makes me sad for a simple repair, but it is too cold, and I am too old.
