2012 BS Thread Extraordinaire! "Let the BS flow"..........
#3886
on
1 Post
They offered 200 people bonus money to move here when they closed Compaq's projector division and merged it with Corvallis. 3 accepted.
They offered over 400 people money to move to Houston when they decided to merge the Corvallis laptop division into Compaq's and had 8 takers.
Apparently it takes a LOT more money than they were offering.
#3887
Received 3,999 Likes
on
I might be able to get a diagram for you out of my hanes manual. Luckily I have never had to mess with them. The closest I've ever come was rebuilding the locking hubs.
#3889
From what I've found, to change the axle tube seals on a Dana 60 front axle you have to pull the shafts, and remove the carrier, then drive them out from the outside and then tap the new ones in from inside the pumpkin. Doesn't sound fun...
#3891
on
Here is what it says in regards to the Dana 60: "F350 (4WD) The axleshaft seals for the front axle are located in the differential case and require removal of the differential/ring gear assembly. This process requires tools and techniques beyond the scope of this manual and therefore should be left to a professional repair facility or dealer service department."
#3892
I found a write-up they did in Diesel Power magazine in their '97 F350. They unbolted the carrier, popped the whole thing out in one piece, drove the old seals out with a long pipe, and used a mallet and large socket to drive the new ones into place. Then popped the carrier back in and re-assembled everything.
Nothing really tricky about it. Just sucks because you have to take the hubs and spindles off, pull the shafts, pull the gears, etc.
#3897
on
I hope it is a "better" joy than the gasket on the 460.
