Coolant flush?
Old Dec 31, 2011 | 10:38 AM
waterboy_fishing's Avatar
waterboy_fishing
Coolant flush?
I have a 101,000+ on my truck with no coolant flush as of yet. I do not have any white smoke so at this point I think my cooler is okay. At this mileage what method of flushing would you recommend? I know there is more than one way in the tech folder so I thought maybe you guys could recommend the best one. What does the dealer do when they flush it?
Old Dec 31, 2011 | 11:03 AM
wulfman's Avatar
wulfman
If i were you just do a distilled water flush and do not use the VC9 iron cleaner . If your not going to be replacing the oil cooler then its not nesessary. Also get a scan gauge and see what your temp spread is first. On a side note my buddy's truck an 04 130000 or so never had the coolant touched , we put my scan gauge on it and he has a better temp spread than me , and i have a new oil cooler.
Old Dec 31, 2011 | 11:04 AM
wulfman's Avatar
wulfman
Oh hows your broken bolt thing going.
Old Dec 31, 2011 | 02:40 PM
waterboy_fishing
Got lucky. Drilled out the hole and re-tapped it to a M6x1.0 thread and put a couple of washers on the new bolt and it torqued down. Didn't know if it would work since I had to grind off the boss where the threads were seized. That was halve my threads gone. Done though and no leaks.
Kdawg89
Jul 19, 2015 01:59 AM
pickle40
Feb 7, 2015 08:19 PM
f350project
Sep 3, 2014 08:06 PM
cabloom300
Dec 29, 2013 02:57 PM
craypc
Apr 4, 2013 07:04 AM
